Go to Post The 4-wheel drive systems bounce around like Mexican jumping beans. It is quite fun to watch. - Warren Boudreau [more]
Unread 01-02-2006, 21:39
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
EasyC Timer and Gyro questions
I can't seem to figure out the answer for two things.
1. EasyC gyro code seems to work well, giving the correct heading when the robot is turned. However we would like to use the actual yaw rate...how can we access this data?
2. We tried to calculate yaw rate ourselves using one of the EasyC timers, however the timer doesn't seem to change. We start it in the Initialize block but subsequent calls return 0, thus we still can't get yaw rate.
We would rather just get yaw rate from the gyro but EasyC doesn't seem to allow this. The reason we want it is so we can use the yaw rate to control our drive better, so that straight stays straight and turns are constant. So if anyone has any ideas on how to do this, we would appreciate the advice!
Unread 01-02-2006, 22:05
AKA: Dan
Re: EasyC Timer and Gyro questions
Hmmm right after I posted my question I think I may have figured out the solution. We can access the gyro output directly with GetAnalogInput(1) which is, of course, the yaw rate, right? Have to wait til tomorrow to try it though. It just figures that after two hours of head scratching that it would be this easy (get it? EasyC!).
That just leaves me with the question of why the timer isn't timing?
In the Intialize block:
StartTimer(1)
In another function:
timer = GetTimer(1);
PrintToScreen ("Time is %ld\n", (long)timer);
I've tried various permutations of casting but get 0 almost every time. Sometimes, if I'm patient, it will go to 1. Any ideas? I should add all of this is taking place on the 2005 RC.
Unread 01-02-2006, 23:16
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
StartTimer(1)
Your not using it somewhere else are you?
In your "other function" is it in the "loop". A While Loop?
Your code looks ok to me. We haven't had any timer problems.
Try timer 6 for kicks and giggles....
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 02-02-2006, 00:20
AKA: Dan
Yeah it is only being used once...I even tried it in the simple gyrotest code and still got nuthin. I guess I will try another one... since your no. 6 timer works, I will try it.
Unread 02-02-2006, 07:31
AKA: Brad
#0190 ( Gompei and the Herd)
As you said in your other post, you can retrieve the raw yaw rate just polling the gyro analog port directly. It returns 12.5mv/deg/sec of rotation. The analog to digital converter returns a value from 0-1024 for the range of 0-5000mv. So by doing some arithmetic, you can create a function that returns the actual rate of rotation directly.
Can you try putting in a print statement when the timer is started and another when you are reading the timer just to verify that it is being started? Also, are you doing a Preset operation on the timer anywhere in your code that might be getting unintentionally executed repeatedly?
Brad Miller
Robotics Resource Center
Unread 02-02-2006, 09:17
AKA: Dan
I will add a print statement for when the timer is started. I assume you mean to use a GetTimer right after initialization? Also there is no PresetTimer call in the code anywhere.
Unread 02-02-2006, 09:40
AKA: Dan
So for the gyro yaw rate, we are using a 300 deg/sec gyro, so 5 mv/deg/sec. However, the ADC still returns 0-1024 right? It's just a matter of scaling (which we've implemented for heading conversion).
Unread 02-02-2006, 10:54
AKA: Brad
Sorry about that... I was assuming you were using the kit gyro.
You are correct, if you use a different gyro, then just look at the gyro spec. And the ADC will return a 10 bit value between 0-1023 (1024 possible values).
Brad Miller
Unread 04-02-2006, 00:33
Dillon Compton Dillon Compton is offline
Jack-Of-All-Trades
FRC #1391 (Metal Moose)
Dillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud of
Send a message via AIM to Dillon Compton
My team is interested in using a slightly more accurate gyro than the one in the KoP...80deg/sec probably wont be enough to do what we want it to do. Can anyone give me an idea of where to start with the code needed in easy C to do this? We plan on using one from the same manufacturer, can I still drag and drop or do I need to write an original function? What is the relationship between yaw rate (the 0-1024 number, I assume?), and degrees rotation?
Thanks,
Dillon
www.metalmoose.com
Unread 04-02-2006, 17:52
AKA: Brad
Thanks,
Dillon
It turns out you can use the existing block and just scale the output. Check out this thread (down at the bottom).
Brad Miller
Unread 09-02-2006, 19:43
MarkVH's Avatar
MarkVH MarkVH is offline
AKA: Mark VanHaitsma
FRC #0288 (RoboDawgs)
MarkVH is on a distinguished road
does the gyro function in easyc return the angle in radians or degrees?
This is my first time using a gyro.
Unread 09-02-2006, 21:19
AKA: Dan
The EasyC call GetGyroAngle(port number) returns the heading in tenths of a degree. Check out the Help section in EasyC. It does a good job of explaining how each of the EasyC functions work.
Accelerometer code ImmortalAres Programming 28 04-06-2005 01:02
Updated: Example Gyro Interface Code Kevin Watson Programming 2 28-03-2005 04:36
Example gyro code released. Kevin Watson Programming 60 17-03-2005 18:32
Gyro Calibration roboticsjenkins Programming 11 21-02-2005 20:39
Using gyro with other analog sensors...again demerski Programming 0 19-02-2005 08:23
