Go to Post I want to help them to get what's made such a difference to me... - Beth Sweet [more]
Unread 01-02-2006, 18:55
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: pic: Team Rush 27 - Shooter Concept
Thanks Paul.
Yeah, basically to make it from scratch in solidworks, I would draw one tooth, and rotate however many times.
Nowadays, gear manufacturers have all CAD drawings in easily converted formats for your applications that you could just drag and drop in.
We customized a gear just the other day from the firstcadlibrary by extruding cuts and what not, and it was pretty straight forward.
Unread 01-02-2006, 21:23
bbehnke bbehnke is offline
The Behnkenator
AKA: Bria
FRC #1676 (Pioneeres)
bbehnke will become famous soon enoughbbehnke will become famous soon enough
Send a message via AIM to bbehnke
ya im not realy a fan of the side by side wheels either. wat i think would be alot better is putting them vertical so u dont have a problem with turning while the ball is in flight due to one whele spining faster/slower than the other. the vertical one would somewhat elimate this factor and it would be a better idea if the bottom one is spinning faster than the top to creat back-spin on the ball. although i looks realy good
Unread 02-02-2006, 00:17
Parker's Avatar
Parker Parker is offline
FRC #1079 (C.R.E.A.T.E.)
Parker is an unknown quantity at this point
Keep in mind that if the wheels aren't spinning at exactly the same speed, the balls won't fly straight. Every motor, even if they're the same design, will spin at different speeds.
Unread 02-02-2006, 00:25
Chriszuma's Avatar
Chriszuma Chriszuma is offline
Jack of all trades
AKA: Chris Hammond
FRC #0068 (Truck Town Thunder)
Chriszuma is just really niceChriszuma is just really niceChriszuma is just really niceChriszuma is just really nice
Send a message via AIM to Chriszuma
A simple chain and sprockets can be used to ensure that both wheels are spinning at exactly the same speed, and additionally eliminate the need for two motors, saving weight. In our mockup testing, this actually outperformed alot of other methods.
2006 T3 World Tour: Great Lakes - Waterloo - Palmetto - IRI
2006 Awards: Motorola Quality - RadioShack Innovation in Control
My website: http://zuma.phire.org/
Truck Town Thunder's website: http://trucktownthunder.com/
Unread 02-02-2006, 00:57
Alekat's Avatar
Alekat Alekat is offline
AKA: Alex
None #0701 (RoboVikes)
Alekat has a spectacular aura aboutAlekat has a spectacular aura about
Send a message via AIM to Alekat
But couldn't you have the same problem with verticle rollers moving different speeds? And instead of having poor accuracy left and right it is poor accuracy up and down? it's a circular goal so either way you'd be likely to miss if you don't match your speeds.
Unread 02-02-2006, 08:41
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
Thanks for all of the great responses......
As for the gear drawing and SolidWorks. I did draw the gear in AutoCad, and I do have it in my solid models, both UG and Inventor. Though it is my general practice to leave that sort of CPU draining detail out of my drawings.
Fear not, for I have built many a turret, and have designed many a spur gear......I have even milled one that was nearly twice that diameter.
The side-to-side design.......
Also not my favorite. We chose it after several prototypes mainly because of it's low profile. A vertical style two-wheeled shooter was becoming to tall, and a one-wheeled design didn't allow for the lowered RPM and increased torque we were looking for in a shooter.
We have tons of adjustability in the design which allows us to tune the wheels for both compression and alignment. To keep both wheels spinning together we've opted to skip any sort of mechanical coupling and just tune the wheels using a tachometer. Worked well for the prototype.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
pic: Team Rush 27 - Up and out! ajlapp Robot Showcase 17 08-02-2006 18:39
Top 10 seasons in FIRST History Karthik General Forum 6 01-08-2005 23:30
pic: Team RUSH 27 Electrical Box austind27 Extra Discussion 20 02-03-2005 19:41
pic: Team Rush 27 - Full Bot Inventor ajlapp Robot Showcase 7 19-02-2005 14:05
