Go to Post If FIRST isn't your life, then you're doing something wrong! - BandChick [more]
Unread 02-02-2006, 08:10
AKA: Brad
#0190 ( Gompei and the Herd)
Re: easyC trouble
Originally Posted by sirbleedsalot
ok i've got my robot to drive and turn, using easyc to write the code, however i have another motor that i want to be able to turn on by pressing the trigger button on the joystick how do i write code for that, and that will turn the motor counter clockwise then if i release the trigger i want the motor to stop then if i press the thumb button the motor will turn clockwise, can someone give me detailed instructions.
Inside the loop where you are driving the robot, you need to read the trigger inputs from the joystick and operate the motors.
To read the trigger inputs, use the "Digital OI Input" block. It returns a 1 or a 0 depending on the state of the trigger. You can check that value and then decide whether or not to drive the motor. To operate the motor, use the "PWM Control" block. It takes a PWM port number and a speed.
Brad Miller
Robotics Resource Center
EasyC v2.0 is mandatory for FVC! skimoose FIRST Tech Challenge 7 14-01-2006 18:37
Kickoff easyC workshop integrated into EasyC help file Dan Larochelle Programming 0 11-01-2006 06:12
EasyC v. 2.0 - New features, custom user functions, and more! artdutra04 FIRST Tech Challenge 1 02-11-2005 13:36
