Re: Placement of the SLU-35 Terminal Lugs
Good luck and see you in Atlanta!
Also remember if your using a solder on connector on the 6 gauge wire use an iron that can get it hot enough. Most common PCB/electronics irons wont putout enough heat to make a good secure connection!
| SLU-35 Terminal Lugs | Mr.D | Electrical | 2 | 23-01-2006 10:49 |
| SLU-70 Lugs | Daniel | Electrical | 46 | 03-05-2005 08:31 |
| New LED Lights this Year, spec for placement? | Chris_Elston | General Forum | 12 | 16-02-2004 17:32 |
