Go to Post "Drink Mountain Dew. Eat Pizza. Make Robot. This is life." - onecoolc [more]
Unread 01-02-2006, 22:38
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Stick Welding Aluminum
I have access to large stick welders and I have lots of experience on steel with them. We'd like to get our frame TIGed, but for time savings, rather than outsourcing, I may need to do it myself (our sponsor shops are incredibly busy). But stick is the only thing I have access to.
I know stick welding aluminum can be done but I've never seen any pictures of what it looks like afterwards.
Please don't tell me "don't stick weld aluminum" unless you yourself have tried it. Please don't say "I've heard it doesn't work well." I only want first-hand info and pictures (yours or found online).
Also, what polarity needs to be used and what shields the arc?
Unread 02-02-2006, 07:31
Gdeaver Gdeaver is offline
FRC #1640
Re: Stick Welding Aluminum
Aluminum can burn well if it isn't shielded with an inert gas. The flux on a welding rod doesn't provide enough protection from the atmosphere.
Unread 02-02-2006, 13:17
Kirk Kirk is offline
FRC #0254
Kirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud of
Send a message via AIM to Kirk
It looks like it can be done http://store.cyberweld.com/alel40.html. Sorry I do not have first hand knowledge. You might call that company that sells the electrodes and see what they say. They are probably your best source of info. Good luck
Kirk
bolting square aluminum without crushing walls greencactus3 Technical Discussion 11 20-01-2006 16:58
Rochester NY Welding Training rees2001 General Forum 4 06-10-2005 14:10
MIG Welding Aluminum sanddrag Technical Discussion 11 15-09-2005 13:50
1 stick drive to 2 stick drive wayne 05 Programming 18 01-04-2004 16:41
Difference in aluminum archiver 2001 1 23-06-2002 23:49
