Go to Post Don't limit programming to just hitting keys, there is a lot of logic/design involved. - Mike [more]
Unread 02-02-2006, 13:51
Max Brin Max Brin is offline
FRC #1943 (Neat Team)
Max Brin has a spectacular aura aboutMax Brin has a spectacular aura aboutMax Brin has a spectacular aura about
Getting our spring streched
Hey,
is it legal to strech our cannon's spring out of the robot 28x38 limits?
Thanks & good luck!
Unread 02-02-2006, 14:21
DjAlamose's Avatar
DjAlamose DjAlamose is offline
AKA: Teh Albie
FRC #0279 (Tech Fusion)
DjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to behold
Send a message via AIM to DjAlamose
Re: Getting our spring streched
Well that all depends upon what you mean by stretching out your spring and what it is used for. If it is used for the shooter and if it means that after the spring is released it stretches out of the 28x38x60 envelope, then no because any part of the shooting mechanism must be contained within the original 28x38x60 ( I don’t know the exact rule number but it is there, R<something> ). This could be very dangerous too if the spring were to come off and go flying.
I didn't know you could get that much power out of a spring?? Out of curiosity how are you planning to reload the shooter, or is it a one time shoot type of a thing??
WHAT TIME IS IT????? 279!!
2006 GLR Safety Award (2nd year in a row)
2005 National Xerox Creativity Award
2005 National Curie Quarter Finalist w/ 1126 and 180
2005 Buckeye Regional Champs w/ 67 and 274
2005 Buckeye Regional GM Industrial Design Award
2005 Buckeye Regional Safety Award
2005 GLR Quarter Finalist
2005 GLR Xerox Creativity Award
2005 GLR Safety Award
2004 Nationals Curie Division Finalist
2004 GLR Champs
2004 Buckeye Delphi Driving Tomorrow Award
2004 Buckeye Quarter Finalist w/ 1001 and 869
2003 GM Industrial Design Award GLR
2001 National Champs
Unread 02-02-2006, 19:40
in between teams
AKA: Luke Van Oort
Your shooting mechanism must be guarded and can't come in contact with other bots.
Team 1219: 2009 - Mentor
Unread 03-02-2006, 01:25
As soon as we test our springs, I will capture it on video, and upload it.
I think it should be around the 05/02 - 08/02. (us: 02/05 - 02/08)
Thanks guys.
Unread 03-02-2006, 14:14
Max,
I would be concerned under the following rules for power storage...
• Storage achieved by deformation of robot parts. Teams must be very careful when incorporating springs
or other items to store energy on their robot by means of part or material deformation. A robot may be
rejected at inspection if, in the judgment of the inspector, such items are unsafe.
Also, if your ball shooter is mounted on a turret, no part of the turret may extend outside the origianl dimensions of the robot.
<S03> Shooter Mechanism must remain inside the ROBOT - Any mechanism used to throw balls must be
contained within the original 28” x 38” x 60”starting envelope of the ROBOT and must be shielded such
that the mechanism cannot make contact with other ROBOTs. A ROBOT that violates this rule will be
considered unsafe per <S01>.
Unread 04-02-2006, 00:35
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
If you're having issues with a spring stretching out of dimensions, you can always make the string stronger(more force to pull) so that you don't have to move it as far to get the same amount of power. Doubling up springs, or wrapping some extra latex tubing around the system always can add some more tension.
Team Website
spring loaded launcher sciguy125 Technical Discussion 6 17-01-2006 22:42
Adaptative Spring - Driving constraint Daniel_H Inventor 2 03-11-2004 14:33
NEW Spring Off Season in NJ Wayne C. Off-Season Events 25 11-06-2004 10:21
Spring Compression in Inventor 6? psychoCHIPMUNKK Inventor 1 23-05-2004 13:44
Bosch Drill Motor Clutch Spring Dimensions?? aaronbr28040 Motors 3 18-02-2004 19:52
