Go to Post Have you ever found yourself staring at a physics problem, not understanding it, then connected it to a past FRC game and suddenly felt the light bulb start shining? - StephLee [more]
Unread 02-02-2006, 10:50
et1337's Avatar
et1337 et1337 is offline
et1337
AKA: Evan Todd
FRC #1317 (Digital Fusion)
et1337 is a glorious beacon of lightet1337 is a glorious beacon of lightet1337 is a glorious beacon of lightet1337 is a glorious beacon of lightet1337 is a glorious beacon of light
Quick Timer Question
So we set up a timer to trigger an interrupt every time it overflows. However, I could not get OpenTimer1(), ReadTimer1(), etc. to work, so we had to manually set up the timer.
My question is, how do I get the timer to overflow faster? Right now it overflows 3 or 4 times per loop.
Timer setup code:
T1CONbits.T1CKPS0 = 1; // 1:8 Prescale (clock=1.25MHz/each tick=800ns)
T1CONbits.T1CKPS1 = 1;
T1CONbits.TMR1CS = 0; // = 0 Timer uses internal clock
TMR1H = 0x85; // Sets most significant byte
TMR1L = 0xED; // Sets least significant byte
T1CONbits.TMR1ON = 1; // Turns on Timer1
IPR1bits.TMR1IP = 0; // Sets Timer1 as low priority
PIE1bits.TMR1IE = 1; // Enables Timer1 overflow interrupt
INTCONbits.GIEL = 1; // Enables low priority interruptions
There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order.
et1337
Unread 02-02-2006, 11:04
Re: Quick Timer Question
You need to store a new value in TMR1H and TMR1L each time you service the interrupt. That value counts up every tick until it overflows and triggers the interrupt again. To make it happen faster, use a larger number to start with.
0x85ED is 34825 decimal, giving 31251 ticks until it overflows at 65536. At 800 ns per tick, that's 25 milliseconds. If you want to drop that to 5 milliseconds, you need 6250 ticks. Store 59286 in the timer, 0xE796.
Unread 02-02-2006, 14:26
et1337's Avatar
et1337
AKA: Evan Todd
Thumbs up Re: Quick Timer Question
Great, thanks alot! You also answered another question I had regarding the amount of time per tick (800 ns). Thanks!
et1337
Unread 02-02-2006, 15:19
Here's an example of using the library calls.
In User_Initialization() (user_routines.c)
OpenTimer1(TIMER_INT_ON &
	 T3_16BIT_RW &
	 T3_SOURCE_INT &
	 T3_PS_1_8);
// #ticks = elapsed_time(sec) * 10**7 / prescale
// #ticks = .004sec * 10**7 / 8 #ticks = 5000
// Maximum for 16-bit 65535 - 5000 (4ms) = 60535
WriteTimer1(60535); /* Preload timer to overflow after 4ms */
In InterruptHandlerLow () (user_routines_fast.c)
if (PIR1bits.TMR1IF) /* TIMER 1 INTERRUPT */
   PIR1bits.TMR1IF = 0; // clear the interrupt flag
   WriteTimer1(60535); /* Reset Timer to overflow in 4ms */
Accelerometer code ImmortalAres Programming 28 04-06-2005 01:02
a quick function question Kashi Chan Programming 3 06-03-2005 20:44
Accelerometer Timer Question psquared Programming 3 12-02-2005 01:34
A quick IR sensor question PBoss Programming 7 28-03-2004 21:02
A quick question Joelster Technical Discussion 6 10-02-2002 09:09
