Go to Post Thanks and don't stay up all night waiting for Lavery Claus! - Beth Sweet [more]
Unread 25-01-2006, 10:26
Rich Kressly's Avatar
Rich Kressly Rich Kressly is offline
Robot/STEM troublemaker since 2001
no team (Formerly 103 & 1712. Now run U.P. Robotics (other programs))
Rich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond repute
Re: Delaware Regional Pilot Vex Tournamnent
First off, congrats to the plannning committee for pulling off one of the best events I've ever been to. JFLL, FLL, and FVC (over 130 teams total) under one roof at the same time - amazing. Lou Rosanio, John Larock, Joe Perrotto, MOE 365, and a host of volunteers should all be very proud of the outcome.
As for the radio glitches that occured in the morning, we now know this:
Three of the competition crystals did not function correctly and were tested after the competition. Testing indicates that one was mislabeled at the factory and two were "dead". By lunch time at the competition, those crystals were identified and removed from the mix and a pre-match crystal check was instituted. To the best of everyone's knowledge this did affect a robot in each of three matches. Local event volunteers and FIRST FVC staff worked together throughout the day solving problems effectively.
In the cases a robots running after match shutoff, etc. there is no definitive answer at this point, but software/code could be a culprit since multiple hardware configurations yielded the same issues.
We have not confirmed that untethered practicing robots interefered with the field and it's highly unlikely this could occur. The crystals that were used on the competition field are not currently available to the public for purchase. Any crystal a team could have used in the pit area couldn't have matched one on the field. The reason that practicing/pit area robots had to be on tether was to keep them from interfering with one another, the field itself was not of concern.
It's important to note that the number of glitches was far outweighed by incredible competition and gracious professionalism on the part of the FVC teams. All of the teams affected by these anomolies made it to the elimiation rounds and two of them were in the finals. We were all glad to see that none of these technical issues had a major negative impact. For a pilot season, FVC is really an exciting experience and the technical lessons learned in Delaware will certainly make the next FVC events that much better.
technology, innovation, and invention without a social conscience will only allow us to destroy ourselves in more creative ways
Unread 25-01-2006, 11:21
Carol's Avatar
Carol Carol is offline
FRC #0365 (MOE)
Carol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond repute
I just uploaded a some pictures taken at the tournament. They're in the 2006 -VEX - Tournament subgallery. Check them out.
(Look closely and you'll see Rich and other faces you might know)
Unread 25-01-2006, 11:32
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
To add to Rich's assessment, at least in one instance where a robot was not responding to controls properly, we (field personnel and referees) verified that only one set of crystals of that frequency was in use and that there were no team transmitters turned on except those tethered on the field. I had one of my referees sweep the pits, just to be sure. In the case of this one team, I believe that there was a malfunction in their controller/firmware causing their problem.
I couldn't agree more! All team members were very respectful and worked well with the field personnel. I was the head ref for this event and it was a pleasure to work with these people. When I had to make calls on the field which affected the match results, all team members made their points clearly and respectfully, and accepted the outcome graciously. The competitors at the Delaware Regional truly defined "gracious professionalism".
I'd add too that the action on the fields was every bit as intense and exciting as any I've seen in five years with the FRC. This was a great competition and my thanks to Moe, all the volunteers and the teams for making it happen.
Pete Kieselbach
Unread 25-01-2006, 19:19
Lots more event photos here:
http://users.wpi.edu/~bamiller/DEFVC/index.html
Thanks to Brad Miller!!
Unread 26-01-2006, 00:48
Bill Moore's Avatar
Bill Moore Bill Moore is offline
Iv2gr8sons
AKA: Be More
FRC #0365 (Miracle Workerz)
Team Role: Team Spirit / Cheering
Bill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond repute
Send a message via AIM to Bill Moore
The Tournament Media Page is now up. Additional photos and video will be posted as they become available.
Three Signs You Are Getting Old: 1) You forget things, 2) You begin repeating yourself, 3) You forget things.
Unread 02-02-2006, 08:45
Carol's Avatar
FRC #0365 (MOE)
Check out this article on the tournament:
http://www.delawareonline.com/apps/p...602020312/1133
The FLL competitions do get more press than the VEX, but there are some good pictures.
Unread 02-02-2006, 15:44
KathieK's Avatar Unsung FIRST Hero
KathieK KathieK is offline
Sometimes FIRST makes my head hurt!
KathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond repute
Send a message via AIM to KathieK
Very nice article! I thought the photos were good and the explanations good as well.
Check out my 2016 Conference presentation, Dumpster Diving: How to Get Stuff for Your Team for Free or at Little Cost
www.usfirst.org | www.nefirst.org | www.firstnemo.org
Helping mentors since 2004
Unread 02-02-2006, 16:05
Carol's Avatar
FRC #0365 (MOE)
Did you catch where they quote John Larock saying that the VEX robots used "rocketballs"?
Unread 02-02-2006, 17:00
Vex isn't using rocketballs this season? Oops, I guess I'd better go back and read the manual!
Canadian Regional geo Regional Competitions 9 03-04-2003 22:58
Regional Team List Jack General Forum 5 03-01-2003 12:05
The 'Big Picture' regarding regional space.. archiver 2000 1 23-06-2002 23:58
Multiple Regionals archiver 1999 55 23-06-2002 22:26
Braodcast and web coverage of regional competitions dlavery Regional Competitions 26 16-03-2002 17:21
