Go to Post I would suggest spending a few more hours digesting the manual before you finalize your designs. You seem to have missed a few key rules. - GaryVoshol [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition
Unread 02-02-2006, 16:05
Re: Speed Controller Data
The data you logged is representative of the DC value of the output but not representative of the power delivered to the motor. The output of the speed controller is itself a PWM signal and only is a steady state battery voltage at PWM values of 0 or 255 when the speed controller is calibrated. All other times it is a pulsed DC output of varying width. The small voltage variations you see just outside the deadband are due to the very short pulses interacting with the complex impedance of the motor. The graphs linked by Joe Ross show current delivered to the motor which is more representative of the actual response of the motor.
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
not quite sure...speed controller...spike. tophq Programming 8 26-03-2004 13:43
Limiting PWM in pbasic archiver 2001 4 24-06-2002 00:38
