Go to Post This is why I love this game. It's like high speed chess with flashing lights and lots of noise. - Karthik [more]
Unread 02-02-2006, 00:45
FRC #0701 (RoboVikes)
How do you aim your shooter?
just wondering how are all you other teams plannign to aim your ball shooting mechanism?
Team 701
Unread 02-02-2006, 01:12
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: How do you aim your shooter?
We have a custom turntable driven by sprocket, chain, and globe motor. It rides on steel and teflon balls. It has about 160 degrees of rotation. On top of the turntable is a tilt mechanism actuated by the van door motor and driven by sprocket and chain. It can go from 0 to 45 degrees.
Of course, all this is just theoretical. We have not even started building it yet.
Unread 02-02-2006, 08:01
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
For control of the rotator, we will be using a joystick to rotate back and forth manually, or will allow the camera to rotate it to face the goal (we have a switch that allows us to change between manual and automatic control). For the speed (we are adjusting speed not angle), we will use a series of 4 push buttons to change a desired speed by small or large intervals for manual control, and the camera will once again change the speed based on automatic control.
Mechanically, the speed control requires nothing extra than what we already had (one of the big CIM motors driving one flywheel), the rotator control will be done using a van door (or window) motor, driven by either a chain-sprocket connection or a belt drive (not sure which).
Unread 02-02-2006, 09:28
Pat234's Avatar
Pat234 Pat234 is offline
None #0234 (www.cyberblue234.com)
Team Role: Human Player
Pat234 will become famous soon enoughPat234 will become famous soon enough
We are using the camera linked to a globe motor to control the tilt through a 30 degree range of motion and the pan angle will be controlled through the drive train to line the robot up accordingly. These both will be controlled through the camera while on offense however the drivers will have some capability to override the camera controls.
Life is a trip the best way to get started is shut your mouth and keep walking. -Anonymous
Unread 02-02-2006, 09:31
kawelch kawelch is offline
Formerly of 1653
FRC #1984
kawelch is a splendid one to beholdkawelch is a splendid one to beholdkawelch is a splendid one to beholdkawelch is a splendid one to beholdkawelch is a splendid one to beholdkawelch is a splendid one to beholdkawelch is a splendid one to behold
Luck and prayer
Unread 02-02-2006, 11:00
Jared Russell's Avatar
Taking a year (mostly) off
Complete auto aim.
Unread 02-02-2006, 11:09
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
We plan to allow the possibility of manual control, but we are focusing on having fully automated aiming utilizing the camera, to shoot on the fly.
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Unread 02-02-2006, 11:45
Spindash54 Spindash54 is offline
AKA: Gregory Walsh
FRC #1468 (J-Birds)
Spindash54 is an unknown quantity at this point
Send a message via AIM to Spindash54
Aim? Who needs to aim? We just hit the fire button and relax...
Unread 02-02-2006, 12:48
bbehnke bbehnke is offline
The Behnkenator
AKA: Bria
FRC #1676 (Pioneeres)
bbehnke will become famous soon enoughbbehnke will become famous soon enough
Send a message via AIM to bbehnke
for our angle adjustment we are using a cam (off-set center circle) to move a plate up and own and for yaw we are using a lazy suzan design and a automatic aim from the camera. the only thing manual is when you want to shoot the balls into the goal and winning the game
Unread 02-02-2006, 12:55
So it seems many teams ARE going the automated aiming route...
Team 701
Unread 02-02-2006, 13:13
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
How do you compensate for the cams varying radius as it moves? The rate at which your pitch changes is never constant.
--Madison--
...down at the Ozdust!
Unread 02-02-2006, 14:17
Many things are nonlinear in this system. Camera tilt angle is not proportional to distance. Distance is not proportional to the required pitch angle. Pitch angle can be, but is not necessarily, proportional to the cam position.
Fortunately, the nonlinearities are all irrelevant if you forego detailed computation and just make a simple lookup table that converts the measured camera tilt directly to the desired pitch adjustment. Creating that table is as easy as moving the robot forward and backwards, measuring the camera tilt, and manually tweaking the pitch adjustment until it works the way you want.
Unread 02-02-2006, 14:34
DjAlamose's Avatar
DjAlamose DjAlamose is offline
AKA: Teh Albie
FRC #0279 (Tech Fusion)
DjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to behold
Send a message via AIM to DjAlamose
I don't know where you got this from but good luck then.
We have our robot fully automated for just about everything. All you need are the equations for speed, angle, height, and distance. Once you have those the RC can control the robot fully based on where it is. In reality you dont need the camera if your robot can keep track of where it is on the field at all times (much easier to use cmucam).
But we plan on haveing 3 different modes for our shooter, fire, off, and store. Can't give details other than 270 degrees, 4 balls per second, and 2 shooting angles. Pneumatics and window motors will be used for aiming the shooter as well as the small cim motors which will provide the speed for throwing the ball, vary that and you can send the ball just about anywhere.
WHAT TIME IS IT????? 279!!
2006 GLR Safety Award (2nd year in a row)
2005 National Xerox Creativity Award
2005 National Curie Quarter Finalist w/ 1126 and 180
2005 Buckeye Regional Champs w/ 67 and 274
2005 Buckeye Regional GM Industrial Design Award
2005 Buckeye Regional Safety Award
2005 GLR Quarter Finalist
2005 GLR Xerox Creativity Award
2005 GLR Safety Award
2004 Nationals Curie Division Finalist
2004 GLR Champs
2004 Buckeye Delphi Driving Tomorrow Award
2004 Buckeye Quarter Finalist w/ 1001 and 869
2003 GM Industrial Design Award GLR
2001 National Champs
Unread 02-02-2006, 16:06
Finding a reliable ball kinematics equation that takes into account spin and air resistance is VERY hard to do on the RC (but not impossible). And that's not even taking into account the trig needed for angle adjustments and converting the x and y coordinates of the target seen by the camera to angles. Try doing the math yourself - in order to get a full-fidelity representation of what your camera sees, you not only need to convert between pixel offset and angle (which is fairly easy), but also take into account that the 2D space represented by the camera's data feedback is in actuality a representation of 3D space. To combine all of these factors together, you have to use some matrix math.
It is MUCH simpler to use look-up tables, and in addition they are always going to be faster. They do all the dirty work of physics for you.
Our team's solution is to slave camera pan to the turret (turret rotation controlled by a feedback loop) and use a constant camera tilt. Then, a look up table for flywheel speed is indexed by the y pixel offset of the target. With the right choice of camera tilt angle and lens, you can see the goal from pretty much anywhere that you could realistically shoot from. It really doesn't get much simpler than that.
Unread 02-02-2006, 19:42
Parker's Avatar
Parker Parker is offline
FRC #1079 (C.R.E.A.T.E.)
Parker is an unknown quantity at this point
[quote=sanddrag] On top of the turntable is a tilt mechanism actuated by the van door motor and driven by sprocket and chain. It can go from 0 to 45 degrees.
You might run into problems shooting close to the center goal with only 0-45 degrees of rotation. If you want to aim at the lower goal just turn down the speed of your shooter.
Shielding the Shooter WebWader125 Rules/Strategy 10 05-02-2006 20:05
Team 1280 Prototype Ball Shooter Shelbykr7 Robot Showcase 8 25-01-2006 09:57
We Aim For The Stars Part III Ken Leung General Forum 5 03-01-2006 16:57
AIM remote in a myspace Bill_Hancoc Chit-Chat 10 26-11-2005 00:28
(part II) We aim for the stars Ken Leung General Forum 6 03-05-2005 16:57
