Common ground for sensors?
Hi,
In wiring up all the sensors we're using this year, I was wondering if we could save some cable and use a common ground (and for that matter, common +5V line too - provided that we can prove that the maximum total current drain on the line is less than what it is rated for). Anybody know if FIRST allows this (my guess is yes, just wanted to be sure). |
Re: Common ground for sensors?
Jared,
You can use a common power point (a 20 amp breaker) as long as you don't have a ton of sensors on it. A big ball of wire attached to one lonely breaker is going to attract the attention of the inspectors. Grounds are the same but I recommend you run parallel wires from the sensors back to some common point. A custom circuit board is great for this. Even if there is nothing else on it, it can provide a convenient (and reliable) spot to terminate the power and grounds and it can be insulated inside a nice plastic box. |
| Common Ground on Limit Switches | Gary Bonner | Electrical | 4 | 18-02-2005 13:24 |
| how important is ground clearance? | Zippiot | Technical Discussion | 10 | 16-02-2005 11:56 |
| Distro block, maxi fuse box, and ground stem | ErichKeane | Electrical | 25 | 20-02-2004 07:19 |
| Our wheels don't touch the ground! | ahecht | General Forum | 12 | 29-01-2002 19:35 |
| Most common.... | Brian Savitt | General Forum | 1 | 05-01-2002 18:34 |
