| View Poll Results: Is your team going aftr the ramp this year? | |||
| Yes, we are going after the ramp |
211 | 90.95% |
| No, we are not going after the ramp |
10 | 4.31% |
| Ramp??? What ramp? |
11 | 4.74% |
| Voters: 232. You may not vote on this poll | |||
#31
Re: Teams going after the ramp?
We are planning on installing a parking brake on one wheel. To mount the ramp we are going to hit it at an angle as fast as we can, engage the parking brake and slide sideways into our parking spot. This way we don't have to worry about tilting backwards! The key component to this plan is speed though!
#32
something i just thought of. you can use the reverse method. how about instead of pinning an opposing robot on you ramp, sit on their ramp and prevent them from coming up. that gives them 5 points but not 25.
#33
#34
If you know they can't get at least one of their robots on their ramp, you will come out +15 by getting all three on your own ramp. You may be able to block the other alliance and then scoot off their ramp at the last second, thus depriving them of the 5 points your bot would have scored. Even so, not much gain for a risky strategy. |
#35
Since i'm seeing a lot of out-of-the-box ideas, what about this? If your robot can shoot well and time's running down, dump a load of balls on their flat part of the ramp. it prevents them getting on the ramp :S. I know its a little bit of a point loss, but it could be worth it.
#36
RATS! I guess yall beat us to our idea already! ![]() |
#38
I see people talking about the 25 point bonus for the ramp but realistically, will most of your alliance partners be able to climb the ramp?
#39
#include<iostream.h>intmain(void){usingnamespacestd;cout<<"I am sure there will be several teams who will design their robot so that"<<endl<<they can help the other robots on their alliance up the ramp."<<endl<<endl;/*don't know if correct*/system(PAUSE);return0;}
#41
Even the best-laid plans sometimes don't work out. Most teams probably plan to get up the ramp, but when push comes to shove, I don't believe many teams will manage to get up the ramp in the crunch of the last seconds.
#42
We hope we can make up the ramp. It would be tough to have your alliance members setting there waiting for you. Maybe they will be able to drag us up???
#43
we at team 815 can go up the ramp from a sitting position at the base of the ramp while carrying 120 lbs. this was one of our main goals
#44
With out any obstructions (balls - other robots) it's relatively easy to go up the ramp straight on. Try it at an angle approach with the robot at competition weight . It's a little more interesting
#45
But then again gyroscopes... gyroscopes... |
| YMTC: Can teams start cutting metal for 2005? | Natchez | You Make The Call | 67 | 07-02-2006 21:55 |
| Finding new teams | Kit Gerhart | Finding A Team | 8 | 13-04-2004 12:05 |
| The top 8 teams will be....(2004) | Jessica Boucher | General Forum | 20 | 24-03-2004 22:31 |
| Robot Collaboration | Karthik | General Forum | 153 | 18-02-2004 03:40 |
| Long post - this year's game was tough - here's why: | archiver | 2001 | 7 | 24-06-2002 03:31 |
