Go to Post A shaft that yielded is just as useless as a shaft that broke. - Chris is me [more]
Unread 31-01-2006, 20:25
Master Dictator's Avatar
Master Dictator Master Dictator is offline
AKA: CJ Myers
FRC #0341
Master Dictator is on a distinguished road
IFI Loader Problem
Okay...my team is having a problem. In IFI Loader 1.10 I can not download to the Robot Controller. It verifies that the controller is connected. When I hold down the program button on the controller and the LED turns solid orange. But... the problem is that in the IFI Loader when I hit "Download" to download the .hex file it starts to download but as soon as it hits the first bar it stops the download and says that it is not connected and the orange solid light is flashing orange. The laptop only has one com port and we tried changing it. The port is also set for the 115200 bit thing too. I also tried removing and re-downloading the ifi loader. No luck any help would rock!
Unread 31-01-2006, 20:48
Electrical Engineer
Rookie Year: 1995
Re: IFI Loader Problem
Try and download the default hex file from IFI. Please be sure that you are downloading 2006 hex to a 2006 controller. My first guess is that you may be trying to load 2005 code to a 2006 controller or vice versa...
Mike Betts
As easy as 355/113...
Unread 01-02-2006, 09:20
You aren't continuing to hold down the program button while it's downloading are you?
Unread 01-02-2006, 12:19
Are you using version 1.0.10 or 1.1.0? There isn't a version 1.10. The exact placement of the 0's and .'s are very important as 1.0.10 will not work with the new robot controller.
Unread 01-02-2006, 16:17
aaeamdar's Avatar
aaeamdar aaeamdar is offline
Post-A-Holic
AKA: Paul Dennis
FRC #1719 (The Umbrella Corp)
aaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant future
The best advice I can give you is to try a lot of different things.
Use the default code (you are essentially controlling for what's wrong).
Then try a couple different computers.
Make sure your serial cables don't have broken and/or missing pins and that they are properly plugged it.
Try re-installing the IFI loader.
Re-boot your computer.
Carefully examine your RC, paying special attention to the program port.
If none of this works, beat your head against the wall and scream, "I HAVE A DREAM... THAT ONE DAY, LITTLE ZEROES AND LITTLE ONES WILL FLOW FROM MY COMPUTER TO MY ROBOT CONTROLLER."
If I think of any more stuff and you're still having problems, I'll post again.
Best wishes!
Paul Dennis
Unread 01-02-2006, 16:53
AKA: CJ Myers
FRC #0341
Well lets see...no I am not holding down program button the whole time. Its version 1.1.0 and I tryed restarting the computer, checked the serial port connections and the RC controller and the cable and reinstalled everything. I also tryed to use the default code.... no luck.
Unread 01-02-2006, 17:01
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Originally Posted by Joe Ross
...There isn't a version 1.10...
No, this isn't quite true.
-Kevin
Kevin Watson
http://kevin.org
Unread 01-02-2006, 17:12
AKA: CJ Myers
FRC #0341
Yea thats the one I have...
Unread 01-02-2006, 19:30
aaeamdar's Avatar
Post-A-Holic
AKA: Paul Dennis
We're using 1.0.12, and we haven't had any major problems. Apparently, it didn't like some of my earlier Cam code (I'm still not sure why) after the download bar was finished, it continued to blink the program light. I'm not asking for help and that's not the problem you've described, I know. I'm just rambling. Don't heed an old man like me.
My best next piece of advice would be to switch RCs. How can one do this? Talk to other teams in your area, see if you can bring your labtop and use their RC for a bit. Try switching cables before you do this.
The objective here is to isolate your problem. Is it the cable, the RC, the computer, the loader, what?
I sure hope you get this resolved.
Paul Dennis
Unread 02-02-2006, 01:09
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Try booting in to Master Only mode. Hold down Program and Reset for about 10 seconds, then release..Reset I think and keep holding Program until you have a green power LED, and an orange program LED, the last three unlit. If that doesn't work try releasing Program and holding Reset.
In this mode the User Processor doesn't boot and you can download code straight to its flash, it might clear up this problem, so far it's been my RC miracle fix.
Matt Krass
Unread 02-02-2006, 17:45
Laughing Maniac Laughing Maniac is offline
AKA: Ethan
FRC #0528
Laughing Maniac is an unknown quantity at this point
Hello, I am one of the programmers for 528. We still have problems using our laptop to send the .hex file to the Robot Controller. The IFI Loader (v. 1.1.0) does through all the steps until downloader the hex file. From there, it loads to the first two bars, stop, and says it's not connected to the RC. Yesterday, I try downloading with my home computer and it worked from there. Right now, I am currently trying to configure the laptop to nearly the same settings to my computer it is still not letting me finish out the download. I'm hoping if you, guys and girls, and help us out.
Thanks!!
Unread 02-02-2006, 17:50
emersont49 emersont49 is offline
#1098
emersont49 is a glorious beacon of lightemersont49 is a glorious beacon of lightemersont49 is a glorious beacon of lightemersont49 is a glorious beacon of lightemersont49 is a glorious beacon of lightemersont49 is a glorious beacon of light
Make sure you don't have the dashboard running. They both use the serial port and won't play well together.
Tim Emerson
Unread 02-02-2006, 17:59
Anime-niac_2.9's Avatar
Anime-niac_2.9 Anime-niac_2.9 is offline
Japanese-crap freak(NOTE AVATAR)
AKA: Alex Abenoja, A-Squared, & Anime
FRC #0599 (Robodox)
Anime-niac_2.9 will become famous soon enough
sounds like me any my eight-year brother in the same room.
THE ROBODOX FORUM
Reading: Suzumiya Haruhi no Yuutsu by Tanigawa Nagaru
Religion: Haruhiism
Unread 02-02-2006, 18:08
AKA: Ethan
FRC #0528
Currently, I do not have the dashboard on the laptop. I might as well show some pictures since some pictures do have 1000 words in them.
Unread 02-02-2006, 18:41
AKA: Ethan
FRC #0528
I like to say beforehand sorry for slowing anybody's browser/Internet for these pictures.
Here are some pictures of start to end...
Opening Screen...
Establishing Port Connection...
Device Found...
Downloading Hex File
Ending Screen...
If this disobey any rules, I can remove the pictures tomorrow, first thing in the morning, my time zone.
IFI Loader Error Team905Animator Programming 6 12-01-2006 22:40
problem loading code with ifi loader psych0gambit Programming 7 25-02-2005 20:43
HELP!!! the ifi loader is giving me errors cdennisxlx2 Programming 6 03-02-2005 14:25
IFI Loader problem - "Invalid HEX file" wun Programming 9 22-09-2004 12:35
IFI Loader problems billstu Programming 22 23-03-2004 11:39
