Go to Post FIRST games are complex and rely on design and intellectual capability much more than the average sport. - Chris is me [more]
Unread 02-02-2006, 17:06
hopkins's Avatar
hopkins hopkins is offline
AKA: Sarah
FRC #1025 (IMPI)
Team Role: Driver
hopkins will become famous soon enoughhopkins will become famous soon enough
Send a message via AIM to hopkins
what do the colors mean? (pwm)
we are trying to wire a banner light sensor and we have to use a digital input from a pwm cable.
Which color wire on the pwm is the digital input? white or red? (we know that black is ground)
Unread 02-02-2006, 17:53
d.courtney's Avatar
d.courtney d.courtney is offline
AKA: David
FRC #0781 (Kinetic Knights)
d.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud of
Re: what do the colors mean? (pwm)
white is input, red is 5v and black is ground
Unread 02-02-2006, 20:01
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
If you are using a Banner sensor, you have to connect the brown wire to +12 V (with a 20 A circuit breaker per FIRST rules), the black wire to the RC ground (or, preferably, to the Breaker Panel's ground) and the blue or white wire to a signal pin of one of the RC's digital in.
I can't remember which one, but one of the outputs (blue and white wires) is NO (normally open) and the other is NC (normally closed). It doesn't matter which one you pick, as long as you keep that in mind while programming the robot.
You won't be using the +5V available from the RC, so it is better to insulate the red wire from the PWM cable.
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 05-02-2006, 21:33
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Unless I'm mistaken, it is the black and white wires on the Banner sensor that are the signal outputs, not the blue and white. The brown would be +5, blue would be ground, and black or white would be your output. When using the black wire as your signal pin, your default value is normally open (0 when unblocked). If using the white wire as your signal, it is normally closed (1 when unblocked).
Hope this helps,
reading hobby PWM sciguy125 Programming 2 17-10-2005 20:47
Compiling Failed Teh Mike Programming 7 09-02-2005 13:27
FYI about using PWM 13-16 with interrupts cabbagekid2 Programming 6 22-01-2005 00:54
Using an Operator Interface with the 2004 EDU RC wirelessly Dave Flowerday Robotics Education and Curriculum 34 19-04-2004 19:06
pwm 13-15 wayne 05 Programming 2 04-10-2003 12:08
