Go to Post "For once, the cake is NOT a lie." The cake claims liar's paradox. :p - JesseK [more]
Unread 02-02-2006, 19:35
GOshin GOshin is offline
FRC #0333
GOshin is on a distinguished road
Db9 port
if the db9 serial port is fried, shouldn't the whole camera stop working?
i am asking this when i tried to calibrate the camera using labview, the serial port did not even come up on the aplication. however i was able to uploadd kevin's camera code to the rc. even though the camera did not move.
also i accenditly attached the ttl adapter to the rc wrong(backwards) and one fo the pins was touching one of the relay pins, the adapter got realy hot.
i quicly turnedoff the rc and removed it. could that have fried the ttl adapter and that is why when i upload kevin's code to the rc the camera does not move or sends data to the terminal window?
CMUcam2 Serial Port Diagnostics Kevin Watson Programming 13 18-02-2006 15:05
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
Camera DB9 / Calibration Port roboticsguy1988 Programming 10 26-01-2005 14:15
New Serial Port Driver Kevin Watson Programming 16 09-01-2005 01:56
