Go to Post Reading Andy Bakers post- priceless :D - thoughtful [more]
Unread 02-02-2006, 12:24
naor52 naor52 is offline
FRC #1578
naor52 is an unknown quantity at this point
Question camera question
Can we use the camera to messure distance?
Unread 02-02-2006, 12:29
DjAlamose's Avatar
DjAlamose DjAlamose is offline
AKA: Teh Albie
FRC #0279 (Tech Fusion)
DjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to behold
Send a message via AIM to DjAlamose
Re: camera question
Yes, the servos will give you an angle at which the camera is tilted at, with this, and some other dimensions, you can calculate the distance you are away from the target.
WHAT TIME IS IT????? 279!!
2006 GLR Safety Award (2nd year in a row)
2005 National Xerox Creativity Award
2005 National Curie Quarter Finalist w/ 1126 and 180
2005 Buckeye Regional Champs w/ 67 and 274
2005 Buckeye Regional GM Industrial Design Award
2005 Buckeye Regional Safety Award
2005 GLR Quarter Finalist
2005 GLR Xerox Creativity Award
2005 GLR Safety Award
2004 Nationals Curie Division Finalist
2004 GLR Champs
2004 Buckeye Delphi Driving Tomorrow Award
2004 Buckeye Quarter Finalist w/ 1001 and 869
2003 GM Industrial Design Award GLR
2001 National Champs
Re: camera question
Indirectly, yes. If you know the actual size of what you're looking at, you can figure out how far away by how big it looks to the camera. Or if you know where it is relative to the camera mount's orientation, you can figure out its distance by how far away from center the camera needs to look in order to see it.
I figure many teams will be using the camera tilt angle and the known height of the vision target (plus a wee bit of trigonometry) to give an indication of the distance to the goal.
Unread 02-02-2006, 12:35
FRC #1578
Re: camera question
How?
Unread 02-02-2006, 16:14
viewtyjoe viewtyjoe is offline
Code Monkey
AKA: Nathaniel Davis
viewtyjoe is an unknown quantity at this point
Send a message via AIM to viewtyjoe
Re: camera question
If you know the tilt angle, the height of the camera, and the height of the center of the target, you can approximate the horizontal distance using the equation distance = (height from camera to target)(cot(tilt angle)).
Unread 02-02-2006, 19:38
Denz's Avatar
Denz Denz is offline
FRC #0772 (Sabre Bytes Robotics)
Denz is on a distinguished road
Send a message via MSN to Denz
Re: camera question
is the tan function built in the program? how do I get it so I can type "tan (angle in radians)" and have it evaluate?
www.sabrerobotics.com
Unread 02-02-2006, 19:56
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: camera question
Yep, you should be able to just call it like that.
Unread 02-02-2006, 23:18
Denz's Avatar
Re: camera question
And that's built in to the camera function or in the default 2006 code?
Unread 03-02-2006, 00:07
Re: camera question
See http://www.chiefdelphi.com/forums/sh...ghlight=math.h for information on the provided math library.
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
CMUCam2 GUI Tilt Question Idaman323 Programming 3 27-01-2006 02:01
Camera Calibration organgtool Programming 0 11-01-2006 23:56
Using camera PWM out Cuog Programming 2 28-11-2005 14:17
Trying to import Camera code into program without. Kingofl337 Programming 1 18-02-2005 00:43
