Go to Post I don't understand why it should matter if your robot is 100% student built, 100% engineer built or somewhere in between. As long as you are Inspired (I word again) FIRST is getting its point and primary goal across. - [more]
View Poll Results: Is your team going aftr the ramp this year?
Yes, we are going after the ramp 211 90.95%
No, we are not going after the ramp 10 4.31%
Ramp??? What ramp? 11 4.74%
Voters: 232. You may not vote on this poll
  #31   Spotlight this post!
Unread 01-02-2006, 14:04
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: Teams going after the ramp?
We are planning on installing a parking brake on one wheel. To mount the ramp we are going to hit it at an angle as fast as we can, engage the parking brake and slide sideways into our parking spot. This way we don't have to worry about tilting backwards! The key component to this plan is speed though!
  #32   Spotlight this post!
Unread 01-02-2006, 14:07
Starke Starke is offline
Producer at The RoboSportsNetwork
AKA: Matt Starke
FRC #0174 (Arctic Warriors); (Alumni: 340 (GRR), 1126 (SparX))
Starke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond repute
something i just thought of. you can use the reverse method. how about instead of pinning an opposing robot on you ramp, sit on their ramp and prevent them from coming up. that gives them 5 points but not 25.
Team 340 | G.R.R. | Alumni/Mentor | 2003-2007, 2010
Team 1126 | SparX | Engineer | 2008-2009
FRCDesigns.com | Engineer | 2011 - Present
Team 174 | Arctic Warriors | Advisor | 2012 - Present
  #33   Spotlight this post!
Unread 01-02-2006, 14:10
Here is a video of Team 1480 parking their robot.
  #34   Spotlight this post!
Unread 01-02-2006, 14:22
GaryVoshol's Avatar
Cogito ergo arbitro
If you can prevent all of them from getting up the ramp this might be something to look at. However, remember you have just given them 5 points, and taken 15 points away from your own alliance. If you are successful in blocking them, the net is +5 for your alliance. But if they can get one robot on the ramp despite your maneuvering to block, the net effect is 0. You would have achieved the same result if you ignored their ramping attempts and just focused on your own end.
If you know they can't get at least one of their robots on their ramp, you will come out +15 by getting all three on your own ramp.
You may be able to block the other alliance and then scoot off their ramp at the last second, thus depriving them of the 5 points your bot would have scored. Even so, not much gain for a risky strategy.
  #35   Spotlight this post!
Unread 01-02-2006, 14:42
Modulardragon's Avatar
Modulardragon Modulardragon is offline
FRC #1236 (Phoenix Rising)
Modulardragon is an unknown quantity at this point
Since i'm seeing a lot of out-of-the-box ideas, what about this? If your robot can shoot well and time's running down, dump a load of balls on their flat part of the ramp. it prevents them getting on the ramp :S. I know its a little bit of a point loss, but it could be worth it.
  #36   Spotlight this post!
Unread 01-02-2006, 15:37
Marcel Marcel is offline
The Fool
AKA: BabyFace
FRC #0059 (RamTech)
Team Role: Scout
Marcel is on a distinguished road
Send a message via AIM to Marcel Send a message via MSN to Marcel Send a message via Yahoo to Marcel
Originally Posted by Koko Ed
Getting up the ramp is a major part of our strategy (it's 5 points at least and 25 if all three bots get up there. Why not do it?). So much so that we emphasized a bot with a low center of gravity as a major design feature (that means we want a bot under three feet tall) .
Another nice thing about robots with a low center of gravity is that it'll be much harder to have someone hit you to fall.
  #37   Spotlight this post!
Unread 01-02-2006, 21:50
AKA: Dan
RATS! I guess yall beat us to our idea already!
  #38   Spotlight this post!
Unread 02-02-2006, 17:37
plutonium83
Posts: n/a
I see people talking about the 25 point bonus for the ramp but realistically, will most of your alliance partners be able to climb the ramp?
  #39   Spotlight this post!
Unread 02-02-2006, 17:46
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
That was my problem; however it looks like most will based on this poll!
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
  #40   Spotlight this post!
Unread 02-02-2006, 18:08
Anime-niac_2.9's Avatar
Anime-niac_2.9 Anime-niac_2.9 is offline
Japanese-crap freak(NOTE AVATAR)
AKA: Alex Abenoja, A-Squared, & Anime
FRC #0599 (Robodox)
Anime-niac_2.9 will become famous soon enough
#include<iostream.h>intmain(void){usingnamespacestd;cout<<"I am sure there will be several teams who will design their robot so that"<<endl<<they can help the other robots on their alliance up the ramp."<<endl<<endl;/*don't know if correct*/system(PAUSE);return0;}
Just try reading this.
THE ROBODOX FORUM
Reading: Suzumiya Haruhi no Yuutsu by Tanigawa Nagaru
Religion: Haruhiism
  #41   Spotlight this post!
Unread 02-02-2006, 18:51
nate234's Avatar
nate234 nate234 is offline
FTC #0234 (Cyber Blue)
Team Role: Student
nate234 has a spectacular aura aboutnate234 has a spectacular aura about
Even the best-laid plans sometimes don't work out. Most teams probably plan to get up the ramp, but when push comes to shove, I don't believe many teams will manage to get up the ramp in the crunch of the last seconds.
  #42   Spotlight this post!
Unread 02-02-2006, 21:04
DCat DCat is offline
Think Purple!
AKA: DGreen
#1108 (Panther Robotics)
DCat is on a distinguished road
We hope we can make up the ramp. It would be tough to have your alliance members setting there waiting for you. Maybe they will be able to drag us up???
  #43   Spotlight this post!
Unread 02-02-2006, 21:42
blaskay16's Avatar
blaskay16 blaskay16 is offline
President/Driver
AKA: Jeremy
FRC #0815 (Advanced Power)
blaskay16 is infamous around these partsblaskay16 is infamous around these partsblaskay16 is infamous around these partsblaskay16 is infamous around these parts
Send a message via AIM to blaskay16 Send a message via Yahoo to blaskay16
we at team 815 can go up the ramp from a sitting position at the base of the ramp while carrying 120 lbs. this was one of our main goals
  #44   Spotlight this post!
Unread 02-02-2006, 22:41
Gdeaver Gdeaver is offline
FRC #1640
With out any obstructions (balls - other robots) it's relatively easy to go up the ramp straight on. Try it at an angle approach with the robot at competition weight . It's a little more interesting
  #45   Spotlight this post!
Unread 03-02-2006, 09:25
DjAlamose's Avatar
DjAlamose DjAlamose is offline
AKA: Teh Albie
FRC #0279 (Tech Fusion)
DjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to behold
Send a message via AIM to DjAlamose
Ok, the space those balls would take up is minimal. It would take 20 or so balls to begin to prevent a robot weighing 145lbs (battery and bumpers) from going up the ramp. Remember your robot needs to be off the carpet not on top of the ramp. Plus if you spat those balls up there you could have just spat them into a goal and gained 20 pts instead of blocking 15 at most. I really do think it is better just to be able to get more points during the play period and not worry about the ramp. But things do change and we hope our top heavy robot can make it up the ramp...
But then again gyroscopes... gyroscopes...
WHAT TIME IS IT????? 279!!
2006 GLR Safety Award (2nd year in a row)
2005 National Xerox Creativity Award
2005 National Curie Quarter Finalist w/ 1126 and 180
2005 Buckeye Regional Champs w/ 67 and 274
2005 Buckeye Regional GM Industrial Design Award
2005 Buckeye Regional Safety Award
2005 GLR Quarter Finalist
2005 GLR Xerox Creativity Award
2005 GLR Safety Award
2004 Nationals Curie Division Finalist
2004 GLR Champs
2004 Buckeye Delphi Driving Tomorrow Award
2004 Buckeye Quarter Finalist w/ 1001 and 869
2003 GM Industrial Design Award GLR
2001 National Champs
YMTC: Can teams start cutting metal for 2005? Natchez You Make The Call 67 07-02-2006 21:55
Finding new teams Kit Gerhart Finding A Team 8 13-04-2004 12:05
The top 8 teams will be....(2004) Jessica Boucher General Forum 20 24-03-2004 22:31
Robot Collaboration Karthik General Forum 153 18-02-2004 03:40
Long post - this year's game was tough - here's why: archiver 2001 7 24-06-2002 03:31
