Go to Post Pretty robots, who cares? Quality robots are another matter. - Steve W [more]
Unread 02-02-2006, 12:36
jgeorge's Avatar
jgeorge jgeorge is offline
AKA: Jacob George
FRC #0078 (AIR Strike)
jgeorge is an unknown quantity at this point
Encoder counting randomly off by x4 factor
Hi all,
I am using Grayhill 63K64 because I have a high speed shaft, 2000rpm, and wanted the ball bearing version of encoder. I am running it directly from the encoder to the 2006 RC input (no flip flop to buffer B phase) using two 3' servo cables. I am also using Kevin's latest version of encoder code (BTW, thanks Kevin, it is good stuff). The interrupt stuff is as is. In the slow loop, I read the encoder counts, do a delta between readings to get velocity at 26.2ms rate, and try to make decisions. Everything compiles and counts except.....
Every time I start the RC, I am never sure if the encoder will count a magnitude off by 4 times or not. For example, when measuring the rotation of spinning beam, I sometimes read vel of 16 ticks/loop or 64 ticks/loop for the same PWM setting to the motor. It appears random, possible related to software changes, but I have not isolated it to whether it is due to my changes or inherent in my hardware setup.
What I mean by random is that with one version, but multiple resets, it appears error repeats itself, always 16 or always 64. When I rewrite code and download, it could change but between resets, the new factor sticks. I do not know why main line coding should affect it because counter is in interrupt. Unless it is because I am using printf statement and the serial drivers (Kevin's, not IFI's) is using interrupts and is higher priority than the encoder interrupt and interfering somehow. I am only printing out about 25 chars every 26.2ms at 115K baud.
I also tried reversing the input 1 and input 11 signals, no luck. I tried moving to encoder 3 (pin 3 and 13, no luck). I have not tried short cable.
Any ideas?
Thanks in advance.
Jacob
JG78
Unread 02-02-2006, 13:27
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Encoder counting randomly off by x4 factor
Originally Posted by jgeorge
Hi all,
Any ideas?
Thanks in advance.
Jacob
As I pointed out in the encoder_readme.txt file, you may need a line driving circuit at high count rates (2100/sec is high) to drive the capacitance of the cabling. Try it at lower spin rates and see if the problem goes away. If you can find a way to gear it down, that would be good. You can also use a 74ACT244 or 74LS244 IC mounted close to the encoder to send the signals through the cabling.
-Kevin
Kevin Watson
http://kevin.org
Unread 02-02-2006, 14:38
Just to reduce the number of variables, try putting in some code to toggle an otherwise unused output every time you compute the delta. Look at that output with a scope to see that you're actually doing it every 26.2 milliseconds. That'll help tell you where to focus your attention.
Look at the encoder output with the scope too, just to make sure that it stays consistent.
Unread 02-02-2006, 15:50
jgeorge's Avatar
AKA: Jacob George
Alan, Thanks for good suggestions. I will try to wrangle a scope from somewhere into the school to check encoder signals. And do the output bit test trick as well. Should give a good picture of situation.
Kevin, Thanks for reply. I will build the board. But, why does it work sometimes? Just marginal you think? I was going to stop all prints and see if it works better as the TX buffer intr. taking too long might interfere with the encoder phase B read causing the problem. Maybe in some versions of code, the print time is synched with the encoder phase B just right! In any case, I agree with you that it appears I will have to build board.
JG78
Unread 02-02-2006, 16:11
Jared Russell's Avatar
Taking a year (mostly) off
I would guess it is marginal.
Unread 02-02-2006, 21:17
FRC #2429
Yeah, it would be great to put a scope on it and see what's happening. Make sure you look at the signals at the robot controller (sorry if I'm pointing out something obvious). If you figure out what's going on please post your findings.
-Kevin
Kevin Watson
http://kevin.org
Encoder Code Kevin Watson Programming 47 18-02-2008 12:56
encoder vs. motor stephenthe1 Programming 55 06-01-2005 22:07
Updated Encoder Code Available Kevin Watson Programming 2 04-01-2005 01:00
how to add steps in the provided encoder program for the edu Zaramel2002 Programming 3 11-02-2004 08:35
Problems counting encoder pulses bludstayne Programming 7 02-02-2004 23:07
