Go to Post FIRST is like pizza. You and I may like different toppings, but in the end it's still delicious pizza. - Billfred [more]
Unread 30-01-2006, 18:20
CronosPrime1 CronosPrime1 is offline
FRC #0321
CronosPrime1 is an unknown quantity at this point
Dead Zones
Greetings,
Can anyone tell me how to change the dead zone that exists by default? That is, I know any input between pretty much 120 and 140 is read as neutral. I don't necessarily want to remove that, but if I did, how would I do so? Also, is anyone else changing their dead zone?
Unread 30-01-2006, 19:47
Re: Dead Zones
The Victor's dead zone can be compensated for in code if you want. Just add 7 or so to the value you're sending to if if it's more than 127, and subtract 7 or so from the value if it's less than 127.
Unread 30-01-2006, 19:55
FRC #0321
Re: Dead Zones
What is the victor's dead zone?
Unread 30-01-2006, 19:57
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Re: Dead Zones
it may be better to expontially map the joysticks so that there is no dead zone but it is less sensitive at lower values
KK4KQO
http://voltair.us
Unread 02-02-2006, 19:35
colman77
Posts: n/a
Re: Dead Zones
We use a lookup table to "curve" our drive outputs...
I don't remember the syntax for defining tables offhand; if you need it let me know and I'll look it up tomorrow.
if you put this in your code...
pwm01 = lookuptable[p1_y];
Say you've moved the joystick slightly, and p1_y = 132. This line will define pwm01 as the 133rd value in your lookup table (since lookuptable[0] is the first number in the list).
You could make that 133rd value anything you want... indeed, you could make all table values from 90 to 170 equal to 127, making a freaking huge dead zone.
Hope that helps
Unread 02-02-2006, 20:33
mogunus mogunus is offline
AKA: Luciano DiFalcone
FRC #1350 (Rambots)
mogunus is an unknown quantity at this point
Re: Dead Zones
Yeah, we do the same thing as the guy in the above post. "Smoothed" lookup table makes the robot move nicer.
... one of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs.
-- Robert Firth
Unread 02-02-2006, 21:53
Re: Dead Zones
It's the range of PWM values that result in the Victor staying in "neutral". I think it's about 8 or 9 counts either side of 127. I saw it defined on the IFI web site somewhere, but I'm not sure where to find it right now.
Unread 02-02-2006, 22:06
aaeamdar's Avatar
aaeamdar aaeamdar is offline
Post-A-Holic
AKA: Paul Dennis
FRC #1719 (The Umbrella Corp)
aaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant future
Re: Dead Zones
I don't know about that. Our initial tests (just playing around with it) seemed to indicate that there was effectively no dead zone. We set ours to 15. We also used the look table, but as seen in the camera code thread, make sure that it's
rom const unsigned char lookTable[XXX] = {x, y, z};
and not this:
 unsigned char lookTable[255];
Ooops. That story didn't end well.
Paul Dennis
Unread 02-02-2006, 22:19
Re: Dead Zones
The main Victor page describes the deadband:
The Victor 884 has a deadband with respect to the PWM signal, which is approximately 117 to 137 (127 center). Any PWM signal within the deadband results in no output (neutral).
A little more detail is given in the IFI Tech Support forum.
White Paper Discuss: 2003 Automated Dead Reckoning Test Code CD47-Bot Extra Discussion 10 07-09-2005 11:25
Dead Reckoning Ryan Cumings Programming 3 24-02-2004 10:57
What to do with autonomous Rickertsen2 Programming 48 17-02-2004 16:22
dead robot in the finals? srawls Rules/Strategy 2 24-03-2002 14:44
