Go to Post To the ball knockers, I salute you. - Brandon Holley [more]
Unread 03-02-2006, 07:25
Re: Common ground for sensors?
Jared,
You can use a common power point (a 20 amp breaker) as long as you don't have a ton of sensors on it. A big ball of wire attached to one lonely breaker is going to attract the attention of the inspectors. Grounds are the same but I recommend you run parallel wires from the sensors back to some common point. A custom circuit board is great for this. Even if there is nothing else on it, it can provide a convenient (and reliable) spot to terminate the power and grounds and it can be insulated inside a nice plastic box.
Common Ground on Limit Switches Gary Bonner Electrical 4 18-02-2005 13:24
how important is ground clearance? Zippiot Technical Discussion 10 16-02-2005 11:56
Distro block, maxi fuse box, and ground stem ErichKeane Electrical 25 20-02-2004 07:19
Our wheels don't touch the ground! ahecht General Forum 12 29-01-2002 19:35
Most common.... Brian Savitt General Forum 1 05-01-2002 18:34
