Go to Post Less playing to the camera, more talking about cool FIRST stuff please. - Cuog [more]
Unread 03-02-2006, 00:19
Dillon Compton Dillon Compton is offline
Jack-Of-All-Trades
FRC #1391 (Metal Moose)
Dillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud of
Send a message via AIM to Dillon Compton
CMU Cam + Lab view Question
Hi All,
I was wondering is if it is possible to get camera calibration values without the CMU cam being attached to the RC? Can I just hook into a computer running labview somehow and read values in on the screen?
Thanks,
Dillon
www.metalmoose.com
Unread 03-02-2006, 00:24
Re: CMU Cam + Lab view Question
As far as I knew, using the Labview app was the only way of getting calibration values.
Team 195 Teaser #3: I could probably give you a more to the point answer. That shows how much I know about that camera.
Download Labview Apps for FIRST
Unread 03-02-2006, 00:58
Jack-Of-All-Trades
To clarify: I am wondering if it is necessary to hook the camera to the RC, the Laptop running Labview to the OC Dashboard port, and get the data that way, or if one can simply hook directly between the laptop and the CMUCam, run labview, and have everything be fine and dandy?
www.metalmoose.com
Unread 03-02-2006, 01:42
Heretic121 Heretic121 is offline
The Resident Gamer -
AKA: Pat or Harry... if you ask its a long story...
FRC #0078 (AIR Strike)
Team Role: Tactician
Heretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond repute
Send a message via AIM to Heretic121
yes you can use the Serial port on the camera itself hook that up to the laptop and have it work fine + dandy...
as far as will you get diffrent values or will the picture be diffrent going through the RC i have no idea *im still trying to figure it out myself =(*
2004 - Team 121 Human Player
2005 - Team 121 Student Captian
2006 - Team 38 Drive Team Coach / Mentor
2007 - 2009 - Team 121 Mentor / Strategery Master
2010 - 2013 - Team 78 Mentor / Strategy / Scouting Lead
2014 - Team 78 coach
Unread 03-02-2006, 10:02
The calibration values already built in to the camera code should work. The lit vision target this year is a consistent color, and is a lot more trackable than the reflective panels last year were.
Unread 03-02-2006, 16:39
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
  1. You can't have the camera connected to a PC and the RC at the same time. It will send to one but not the other.
  2. Last year's Java GUI still works, although it is somewhat buggy.
Unread 06-02-2006, 12:02
Jack-Of-All-Trades
Who says that I'll be traking the vision target?
www.metalmoose.com
CMU Cam not Tracking Properly on Robot coastertux Programming 6 29-01-2006 00:02
Question regarding commands of CMU Cam - Not listed in the guide Phreakuency Programming 2 13-01-2006 08:00
Cam interupt question Collmandoman Programming 8 24-03-2005 00:44
Auton Cam scaning question... Zalumaskov Programming 0 04-02-2005 11:01
pic: (447) Our CMU CAM BOX rufu5 Extra Discussion 2 17-01-2005 19:10
