Go to Post I am really glad that FIRST gives teams the choice to use either students or adults in this role. - dtengineering [more]
Unread 29-01-2006, 19:07
bush's Avatar
bush bush is offline
AKA: Aaron
FRC #0710 (Pine Crest School)
bush has a spectacular aura aboutbush has a spectacular aura about
Send a message via AIM to bush
Servo input values
Is the range of input to the servos 0-255?
Unread 02-02-2006, 19:08
chrisinmd's Avatar
chrisinmd chrisinmd is offline
AKA: Chris Pickett
FRC #0888 (Robotiators)
chrisinmd is a jewel in the roughchrisinmd is a jewel in the roughchrisinmd is a jewel in the rough
Send a message via AIM to chrisinmd
Re: Servo input values
yes
they operate on the same PWM signal that the victors do
knowing this, you can use the servos in the kit to test your code w/out hooking up speed controllers and motors, just plug the servos in to the robot controller
make sure you plug in a backup battery, that's where they get their 7.2v from.
-Chris
Unread 03-02-2006, 11:01
Jared Russell's Avatar
Taking a year (mostly) off
NO!!!
0-254, just like any other IFI pwm signal.
255 is reserved for a special "beginning of data packet" byte - you can get some wacky behavior if you use it. Stick to 0-254.
Unread 03-02-2006, 12:10
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
The new controllers automatically replace 255s with 254s to fix that exact problem. On the old PBASIC controllers, if you sent pairs of 255s you'd get all kinds of problems...
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 03-02-2006, 17:41
chrisinmd's Avatar
AKA: Chris Pickett
Originally Posted by Abwehr
NO!!!
thanks for correcting me, I need to be getting more sleep!
-Chris
Unread 03-02-2006, 18:49
Check the data sheet for the individual servo to determine it's exact response, i.e. angle vs. PWM.
Servo Values to Degrees... How? mogunus Programming 16 11-04-2007 02:03
Servo Values DanDon Motors 8 14-02-2005 15:49
Dashboard View of Pan and Tilt Servo Values JoeXIII'007 Programming 1 02-02-2005 22:34
