Go to Post I don't care if you use hot dogs for wheels. If you're scoring points, and you fit the strategy, it's fine. - evanperryg [more]
Unread 02-02-2006, 20:17
VEN's Avatar
VEN VEN is offline
The future isn't what it used to be
AKA: Volodymyr
VRC #0478 (Mustang Robotics)
VEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to all
Send a message via MSN to VEN
mounting andymark wheels
I recieved the wheels and they seem different from the ones in the cad drawing or the ones in the pics on the side. How do you guys mount your wheels to the shafts withouth them moving sideways?
Unread 02-02-2006, 21:47
bombadier337's Avatar
bombadier337 bombadier337 is offline
1337 U53R
AKA: Shaver
None #1541 (MidloCANics)
bombadier337 is just really nicebombadier337 is just really nicebombadier337 is just really nicebombadier337 is just really nice
Send a message via AIM to bombadier337
Re: mounting andymark wheels
We used 1/2 keyed drive shaft and used the new universal hubs. We placed the hub on the wheel and cut some keystock the length of the hub. We then put collars on either side of the wheel to keep it from sliding.
Midlothian High School - Team 1541
2005 Radioshack Innovation in Control - NASA/VCU Regional
2005 Rookie Inspiration - NASA/VCU Regional
Unread 02-02-2006, 22:57
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Yeah, use the universal hubs with 1/2" keystock and shaft collars.
Unread 02-02-2006, 23:30
VEN's Avatar
VEN VEN is offline
AKA: Volodymyr
cool..but one problem...these are the front and forward and will be spinning ON the shaft not with the shaft...so how do you keep them in place then...the andy mark wheels turned out different
Unread 03-02-2006, 00:54
Collin Fultz's Avatar
Collin Fultz Collin Fultz is offline
no team (IndianaFIRST)
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
Can you post a pic? People may have more options for you if they see what you're talking about. Or you could try to contact AndyMark directly.
Collin Fultz
Unread 03-02-2006, 02:24
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
If they are going to be non-driving wheels, use brass tubing as a spacer to center your wheels. Works for us
Just find some tubing with the I.D. the same as your shaft O.D.
Hope this helps.
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 03-02-2006, 10:28
VEN's Avatar
VEN VEN is offline
AKA: Volodymyr
that was the original idea but these wheels are retarted...first off the roller bearings inside have like 5mm of sideways movement...if we use brass tubing on the plastic cap which holds the bearing in, the plastic will get worn out in minutes...if we take it off and put the brass tubing up to the bearing it wont do anything because the wheel will not be supported, the bearing will be...the only way we see to do this is with a thrustbearing
Unread 03-02-2006, 11:09
VEN's Avatar
VEN VEN is offline
AKA: Volodymyr
Unread 03-02-2006, 14:48
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Is it possible that these wheels aren't designed or the right style for the type of application you are doing? Couldn't you use the universal hub and then make the shaft spin in something other than the wheel? (i.e. another bearing mounted in a frame, etc.)
Just curious, did you take the plastic cap off or did it fall off?
Purdue Alumni
Cummins, Inc.
Unread 03-02-2006, 15:07
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
This application simply needs some tubing and some washers. Cut some aluminum tubing or PVC pipe (with an id of .75 or greater) to the right length (minus about 1/8") to locate your wheel on your shaft. Then, put a 3/4" id washer between the wheel and the tube. The outside diameter of the washer needs to be big enough to act as a shoulder for the wheel's plastic hub. Washers will capture the wheel. Tube (or PVC pipe) will capture the washers.
Good luck,
Andy
Unread 04-02-2006, 00:14
VEN's Avatar
VEN VEN is offline
AKA: Volodymyr
thanks Andy but we solved this another way...strip the inside of the wheel, take out the bearing..then make metal caps which go in place of the plastic ones, the will also house ball bearings, the shaft will sit on that...it will then require some spacers yes
THANKS
AndyMark and IFI Compatibility Kevin Kolodziej Kit & Additional Hardware 10 31-01-2006 10:04
AndyMark Omni Wheels Wayne Doenges Technical Discussion 11 25-01-2006 23:54
mounting the wheels Stormhammer Technical Discussion 8 28-01-2005 14:41
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
