Re: problem with using a loop
You should show us the section of the program you're talking about. You should tell us what you expect it to do. You should tell us exactly what it is doing instead.
(And you should probably let us know what you mean when you say "this mplab", because I'm pretty sure most of us think MPLab is the program that we run on a Windows PC in order to write and compile programs for the robot.) |
| Loop time for OperatorControl function? Debug blows... | Chris_Elston | Programming | 10 | 13-02-2006 14:42 |
| While Loop Require in OperatorControl? | Chris_Elston | Programming | 2 | 15-01-2006 14:29 |
| Need a realistic Statics Problem | sanddrag | Technical Discussion | 10 | 05-12-2005 15:07 |
| arm-limitting gyro PD loop producing some strange results | ZZII 527 | Programming | 8 | 16-02-2005 02:30 |
| Rewriting main loop | Max Lobovsky | Programming | 4 | 04-01-2005 18:35 |
