Re: problem with using a loop
What do you expect that code to do? It's very likely that you want to use an if statement, not a while.
| Loop time for OperatorControl function? Debug blows... | Chris_Elston | Programming | 10 | 13-02-2006 14:42 |
| While Loop Require in OperatorControl? | Chris_Elston | Programming | 2 | 15-01-2006 14:29 |
| Need a realistic Statics Problem | sanddrag | Technical Discussion | 10 | 05-12-2005 15:07 |
| arm-limitting gyro PD loop producing some strange results | ZZII 527 | Programming | 8 | 16-02-2005 02:30 |
| Rewriting main loop | Max Lobovsky | Programming | 4 | 04-01-2005 18:35 |
