Go to Post only here would you find someone calling a motor cute.... - Denman [more]
Unread 03-02-2006, 17:36
Calvin Calvin is offline
Calvin has a spectacular aura aboutCalvin has a spectacular aura about
Variable question (solved)
OK i'm going to be sitting by my computer refreshing every 30 seconds checking for reply
In file user_routines.c, under
/***DEFINE USER VARIBLES AND INITIALIZE THEM HERE ***/
I added:
static unsigned int bob = 2;
Now under the:
Void Default_Routine(void)
if(bob == 2 && p1_sw_trig){bob = 0;}
if(bob == 0 && p1_sw_trig){bob = 1;}
if(bob == 1 && p1_sw_trig){bob = 0;}
Before I click on the trigger, I get the value 2 for bob...
Click on it once, I get 0
click on it again I get 0(it's suppose to change to 1)
WHAT AM I DOING WRONG!?!!?
Please help!
Unread 03-02-2006, 18:06
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
Re: Beginning programmer: Variable question HELP!!!
Your problem is that you set bob to 1 and then check to see if it is 1 and the button is pressed and set it back to 0.
  bob = 0;
/** assuming bob == 0, bob is set to 1 ****/
  bob = 1;
/** bob is now 1 and gets set to 0 ****/
  bob = 0;
/*** bob is always 0 if the trigger has been pressed ***/
You can fix this with by using an else if.
    bob = 0;
  else if(bob == 0 && p1_sw_trig)
    bob = 1;
  else if(bob == 1 && p1_sw_trig)
    bob = 0;
Once you do that you're going to run into the problem that the state is constantly toggling between 0 and 1 when the button is pressed.
This is because there is no way that you as a user will be able to tap the trigger for 1 loop (1/42 of a second) and the trigger will actually be pressed for multiple loops.
What I think you want to do is keep track of the previous button state and only change states if your current state is pressed and your previous is not.
Unread 03-02-2006, 18:08
RIgnazio RIgnazio is offline
Team Role: Webmaster
RIgnazio will become famous soon enough
Originally Posted by Calvin
OK i'm going to be setting by my computer refreshing every 30 seconds checking for reply
I added:
Now under the:
Please help!
Try this:
static unsigned int trigger_count = 0;
if(p1_sw_trig)
++trigger_count; //sets a trigger counter to control the value
else
if(trigger_count > 1) //Change as needed
trigger_count = 0; //Resets trigger count
else
if(bob == 2 && p1_sw_trig && trigger_count == 0)
bob = 0;
else if(bob == 0 && p1_sw_trig && trigger_count == 1)
bob = 1;
else
Electrical Engineer
Rookie Year: 1995
It takes about 400 to 600 nanoseconds (maybe a bit more) for the three IF statements to execute. You cannot hit the trigger fast enough to satisfy only one IF statement.
The first time through, bob goes from 2 to 0.
The next time though, bob goes from 0 to 1 to 0.
The code is doing exactly what you told it to do...
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 03-02-2006, 18:12
wow thanks for the quick reply,
I figured out a way to do it with two buttons. Now it works fine.
I completely forgot about the quick loop, and started questioning my programming skills.
PHP Code:
/////**** Start of RELAY 7 code ****/////
if(bob7 == 0)
printf("Bob7 = 0\r");
relay7_fwd 1;
    if(
bob7 == 1)
printf("Bob7 = 1\r");
relay7_fwd 0;
    if(
bob7 == 2){printf("Bob7 = 2\r");}
    if(
bob7 == && p1_sw_trig){bob7 0;}
    if(
bob7 == && p1_sw_top){bob7 1;}
    if(
/////**** End of RELAY 7 code ****/////
VEX programming Gene F Programming 14 08-08-2006 22:21
Printf Oddity : Programming Challange DarkAlex Programming 7 21-03-2005 08:12
have a question to ask about Double Solenoids to one spike programming davelu Programming 3 22-02-2005 09:52
General programming question mikesown Programming 1 07-02-2005 16:09
'Fix It Window' and Programming.... JMac Programming 19 25-01-2005 18:57
