Who has the camera working?
If your team has the camera working, could you please post here? It would be greatly appreciated. Our team is curious to know if everyone else is having difficulties as well.
Re: Who has the camera working?
we have ours working, what is ur problem
Team 808, |
We got ours working using the Kevin Watson code with minor tweeks.
Ours is working perfectly. We did it the "hard way" without Kevin's code.
Post any problems you are having and we will try to answer them! |
Got it working and even have had an old robot driving toward the green light by the second week.
#7
Camera works fine.
We just have to develop the shooting algorithm based from it now... |
#8
we also had problems with the camera, we couldn't make it track green with Kevin's code, so we developed our own code for the camera (tracking and searching).
feel free to download our code here or ask questions about it. good luck! ![]() |
#9
we have the camera "working", we are getting output in the IFI_Loader window for pan and tilt, but the camera itslef is not moving.
#10
I got it working! Kevin coded it to tilt the wrong way when it found the target. To fix this go to tracking.c. In the servo track function, find the y-axis/ tilt tracking code. Where it assigns the tilt error, multiply the whoole subtraction problem by -1. THen go down and find the two places where it assigns 1 or -1 to the step in a division erro occurs and reverse them. That should fix the problem.
#12
Or go to tracking.h
// If your camera suddenly moves away from the target once // it finds it, you'll need to change the sign on one or // both of these values. #define PAN_ROTATION_SIGN_DEFAULT +1 #define TILT_ROTATION_SIGN_DEFAULT +1 change the value there. lol It's alot easier ![]() |
#13
Ours is working but the last time I checked it would follow our faces rather than the green light we had. Probably because the green light was iluminated on our faces but whatever as long as it follows green right?
#14
we got our camera working and we our using pixels to tell how far away our robot is from the goal and how much force it will need to hopefully go in
#15
Our camera works but we're still playing with the code to make it track the way we want it to.
| CMU Camera kills robot controller if not found. | Chris_Elston | Programming | 21 | 27-03-2006 14:30 |
| Camera not working | st1nkm4n | Programming | 7 | 02-02-2006 08:22 |
| Unresponsive camera | neilsonster | Programming | 9 | 17-02-2005 08:51 |
| Camera not working when connected to robot | MarkVH | Programming | 5 | 14-02-2005 15:40 |
| Camera stops working when we use camera_set_servos()... | SeanCassidy | Programming | 16 | 13-02-2005 03:08 |
