Go to Post There is no MILSPEC standard for pool noodles. - Rick TYler [more]
Unread 03-02-2006, 16:40
DemonYawgmoth's Avatar
DemonYawgmoth DemonYawgmoth is offline
AKA: Artem Kochnev
FRC #1396 (Pyrobots)
DemonYawgmoth is an unknown quantity at this point
Send a message via AIM to DemonYawgmoth Send a message via MSN to DemonYawgmoth
Edit- Can we connect more than one speed controller fan per breaker?
Edit- Apparently our electronics guy was not clear in his request, and wanted instead to know if we were allowed to connect more than one speed controller fan per breaker. Thanks in advance.
Last edited by DemonYawgmoth : 03-02-2006 at 16:54. Reason: Stupid electronics guy
Unread 03-02-2006, 17:05
Imajie Imajie is offline
AKA: James Letendre
FRC #0195 (Cyber Knights)
Team Role: Electrical
Imajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud of
Send a message via AIM to Imajie
Re: Edit- Can we connect more than one speed controller fan per breaker?
I don't know if you can, but I can't see why not.
However, it is easier to connect the fans directly to the 12V and ground on the speed controller itself since it gives you less wires.
Unread 03-02-2006, 17:31
ganging all your fans on one breaker could end up being expensive.
If you wire the fans directly to the 12V input side of each victor, then as long as the victor has power, it has cooling.
If you run the fans off a separate breaker, or put all the fans on the breaker for one victor, then you could end up having all your fans stop when one victor trips its breaker, or if something trips the fan breaker.
then everyone on your team will have to join hands and sing:
"Slow Talking Walter! The Fire Engine Guy!"
(smoke on the water, a fire in the sky :^)
Unread 03-02-2006, 18:24
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
One time, we put all our fans on one breaker. Worked great. The flaw in this idea is if that breaker trips, your screwed. However, if you have good wiring, even 10 stalled fans shouldn't trip a 20 amp breaker. As long as you have no shorts, you should be fine.
Connecting the fan to the power side of the victor is probably a better option but the victor heats up when it is pulling too much current. And when it pulls too much current, it trips the breaker, killing the fan too, and now it has no fan when it needs it most.
Neither setup is ideal. Both work well enough.
Unread 03-02-2006, 18:26
AKA: Artem Kochnev
thanks a lot guys, ill relay the information to our electronics guy.
Unread 03-02-2006, 18:43
One more reason to wire the fan to the input side of the speed controller... When all fans are spinning, you know all controllers are recieving power.
Unread 03-02-2006, 20:00
Originally Posted by sanddrag
One time, we put all our fans on one breaker. ... As long as you have no shorts, you should be fine.
its the unexpected things that will do you in, like a bolt falling off another robot, across your fan circuit breaker, or wires getting pinched in a collision.
Unread 03-02-2006, 21:37
Chriszuma's Avatar
Chriszuma Chriszuma is offline
Jack of all trades
AKA: Chris Hammond
FRC #0068 (Truck Town Thunder)
Chriszuma is just really niceChriszuma is just really niceChriszuma is just really niceChriszuma is just really nice
Send a message via AIM to Chriszuma
We've always hooked the fans up to the victor inputs, I can't imagine the mess of wires you would have connecting them all to the breaker; we have enough of a jungle as it is.
2006 T3 World Tour: Great Lakes - Waterloo - Palmetto - IRI
2006 Awards: Motorola Quality - RadioShack Innovation in Control
My website: http://zuma.phire.org/
Truck Town Thunder's website: http://trucktownthunder.com/
speed controller max speed Team 668 Programming 15 13-02-2005 14:05
Speed controllers won't communicate w/robot controller steven114 Control System 12 03-02-2005 21:26
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
not quite sure...speed controller...spike. tophq Programming 8 26-03-2004 13:43
How do you connect the speed controller fans? Iain Electrical 7 31-01-2003 07:05
