Go to Post Off time, at a regional? What is that? - DonRotolo [more]
Unread 03-02-2006, 17:35
Alex Burman's Avatar
Alex Burman Alex Burman is offline
∆o□
AKA: The Burmanator
FRC #0075 (Roboraiders)
Alex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud of
Send a message via AIM to Alex Burman Send a message via MSN to Alex Burman Send a message via Yahoo to Alex Burman
Holonomic/Omni vs Defense
I have been seeing allot of teams and talk about having holonomic or omni wheel drive. I'll be the first to admit I don't know everything about them or the differences between the 2, if any.
But I was wondering what everyones thoughts were on how a robot using a holonomic or omni wheel drive system would stand against being rammed by a defensive robot? If it were to be hit in the side as its trying to aim or shoot wouldn't it be more likely to be pushed/pushed easier and thrown off target?
The Burmanator
www.Roboraiders.com
http://www.myspace.com/burmanator
Unread 03-02-2006, 17:42
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Re: Holonomic/Omni vs Defense
I figured Omni's would get pushed all over the place the same way robots with casters do.
Unread 03-02-2006, 20:38
CraigHickman
Posts: n/a
Yeah, Holonomic's are never auite good at defense. However, with a good driver and some nice programming, you can avoid being pushed by dodging.
From a more technical perspective, It's actually quite clear why Holonomic's get pushed easily. Most of the time their rollers are made out of plastic, which when smooth isn't the best traction surface. Therefore a more gripping surface, like wedgetop, will have better traction.
Unread 03-02-2006, 20:48
Andrew Blair's Avatar
FRC #0306 (CRT)
Originally Posted by 114ManualLabor
Yeah, Holonomic's are never auite good at defense...
I'm quite convinced that this year, omni's will, to an extent, rule the defensive end of the game. The fact is, there appear to be many low shooting robots, and with an omni-drive "hovering" in front of an opposing shooter, they can, in effect, stop them completely.
As far as corner goal blocking goes, because there are only two defensive robots, defenders will need to perform double duty. A fast, manueverable robot (omni) will be able to quickly block shots, then run to a corner and get in the way of a corner goal dumper. You don't need to be able to push to defend the corner goal; you just need to sit in front of it. Anyone pushing you will only be digging themselves in deeper.
Now, as soon as a shooter has a 5' shooter, all bets are off. In my opinion, pushing ability is only useable (realistically) when *violently* offronting a shooting robot, or pinning an opponent to keep him from going to the corner goal. The better robots will be able to shoot even if you pin them.
-Sir Francis Bacon
-Albert Einstein
Unread 03-02-2006, 21:25
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Omni wheel robots are going to be murdered this year...
Push an omniwheeled robot with a 4/6 wheel or tank driven robot, and they are going wherever you say... they can't help it. As Blair said, Omniwheel bots will be more agile, but if I have an omniwheel bot in front of me, all I'd have to do is push him out of the way. But... omniwheels will be much better suited to shooting on the fly and dodging regular defensive bots... I guess we'll have to see.
Unread 03-02-2006, 22:54
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
I expect omin drive robots to be very powerful offensive robots (manuverability plus the ability to shoot well is quite a combo). On defense they will work well for standing in front of an opponent, but against tall shooters (like ours will be), they're pretty powerless.
Unread 03-02-2006, 23:07
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Depends on how you do it. I'm pretty sure our omni will be able to handle this.
Unread 04-02-2006, 01:50
Jared Russell's Avatar
Taking a year (mostly) off
By design, a standard holonomic drive (4 omniwheels at 45 degree angles or 4 mechanum wheels) only use about 70 percent of the available power for translation at any given time - simply because the rest is busy fighting the other wheels to stay straight. And that's not even taking into account traction differences.
We quickly ruled out omni-wheels this year because we determined that being unmovable was more important than being holonomic - and we can still spin on a dime. Defensively, yes, it is nice to be able to hover right in front of someone - but you can only be 5 ft tall, and many robots (ours at least) will be able to fire over that easily. Bumping and pushing seem to be the order of the day.
Unread 04-02-2006, 02:30
dtengineering's Avatar
AKA: Jason Brett
What if an omni-wheel equipped robot has a pneumatically activated platform that deploys to lift the wheels slightly off the ground.
Get in position, drop your platform, and you've got, say, two square feet of high-friction contact area.
Do your shooting, pick it up and go... while other robots drain their battery trying to move you.
Of course we're not using this strategy... but I'm sure with over 1,000 robots, that someone, somewhere is.
Jason
Unread 04-02-2006, 16:22
Henry_Mareck's Avatar
Henry_Mareck Henry_Mareck is offline
FRC #0418 (Purple Haze / LASA Robotics)
Team Role: Student
Henry_Mareck is a jewel in the roughHenry_Mareck is a jewel in the roughHenry_Mareck is a jewel in the rough
Send a message via AIM to Henry_Mareck
you dont necesarily need to move them- if you push on a corner and spin them it has a good chance to throw off shooting, and unless they have a 360 degree shooter, then if you push them to the non-shoot region, they have to retract the brake, move, and lower it again.
Unread 15-02-2006, 12:10
sgsdragons's Avatar
sgsdragons sgsdragons is offline
Team1595
AKA: Josh Lambeth
FRC #1595 (The Dragons)
Team Role: Driver
sgsdragons will become famous soon enoughsgsdragons will become famous soon enough
Our robot this year has the machanum wheels and it is actually fairly hard to push our robot around. I am the driver and I think that is someone is pushing me around, I will be able to counter the attack.
Just my 2cents
Josh
Team Driver/Designer
2005 Pacific Northwest Regional Winners
2005 Pacific Northwest Regional Judges Award Recipiants
Our Team would like to thank both Team 492 and Team 604 for helping our team win the Pacific Northwest Regional.
2006 Season...
Reginal Event: Las Vegas!!!
Nationals: Atlanta!!!
Unread 15-02-2006, 12:38
DjAlamose's Avatar
DjAlamose DjAlamose is offline
AKA: Teh Albie
FRC #0279 (Tech Fusion)
DjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to behold
Send a message via AIM to DjAlamose
Ok, being able to push robots around will help lots against shooters but it wont help a 1pt bot at all if there is a robot in front of the goal. There is nowhere to push that robot except into the goal, which would be at the fault of the defending robot not the pushing robot. If you plan to protect a corner goal then you had better be prepared to either go into the goal or have some way of preventing it.
I was always under the assumption that holmonic was 4 omnis in the corners and then 2 traction in the middle. With this you should have no problem pushing, its just spinning thats a problem. omni bots will probably do well this year as long as they can make them fast, i have seen a few omni bots that weren’t all that fast.
WHAT TIME IS IT????? 279!!
2006 GLR Safety Award (2nd year in a row)
2005 National Xerox Creativity Award
2005 National Curie Quarter Finalist w/ 1126 and 180
2005 Buckeye Regional Champs w/ 67 and 274
2005 Buckeye Regional GM Industrial Design Award
2005 Buckeye Regional Safety Award
2005 GLR Quarter Finalist
2005 GLR Xerox Creativity Award
2005 GLR Safety Award
2004 Nationals Curie Division Finalist
2004 GLR Champs
2004 Buckeye Delphi Driving Tomorrow Award
2004 Buckeye Quarter Finalist w/ 1001 and 869
2003 GM Industrial Design Award GLR
2001 National Champs
Unread 15-02-2006, 12:44
sgsdragons's Avatar
Team1595
AKA: Josh Lambeth
Team Role: Driver
I will post a video of our machunam drive. IT's REALLY FAST!!!!!!!!! We have the wheels connected directly to the output shafts from our transmisions.
Josh
2006 Season...
Unread 15-02-2006, 14:41
Nope, it's four in the corners at 90 degrees to each other. Normally, that is. Mechanum wheels could beat those pretty well (4 vs 2 isn't a contest normally). Most teams that use omnis use them 2 at one end and two high-traction wheels at the other.
Unread 15-02-2006, 14:46
DjAlamose's Avatar
AKA: Teh Albie
I knew what omni was but I didn’t know it was also called holmonic. But last year we had standard tank style drive with four wheels and they were all omni. We did this because our robot needed really good maneuverability and we could slide into place in front of the tetras. It was quite nice except when we were pushed from the side... o well. I can’t wait to see the video, I’m always interested in seeing other robots and how they work.
2004 GLR Champs
Who plays better defense, Midwest or Northeast? JVN General Forum 32 03-07-2005 19:59
offense or defense ewankoff Rules/Strategy 14 11-01-2005 22:33
Where's the defense this year? rourke Regional Competitions 68 01-04-2004 22:18
Back to Defense for a minute. archiver 2001 34 24-06-2002 03:57
What's so great about defense? archiver 2001 17 24-06-2002 03:46
