Go to Post Welcome to adulthood. Remember, patience is your friend. Denial is your shield. Bitter disinterest your salve. Your endless hours of crushing workload will be your strength. Good luck, soldier. - Koko Ed [more]
Unread 04-02-2006, 00:16
amateurrobotguy's Avatar
amateurrobotguy amateurrobotguy is offline
Lead Programmer/Senior Engineer
amateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these parts
Need some help with a ball launcher
How do we actually get from the motor to the wheel? Do we need a gear box->sprocket-->Chain-->nother sprocket-->wheel? How do we make the gearbox aside from using the same thing that are used in our wheels?
I quit FRC over 2 years ago (more if you're reading this past 2010).
Unread 04-02-2006, 00:48
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
Re: Need some help with a ball launcher
this will depend on three factors:
desired RPM of the wheel,
size of the wheel,
which motor you're using.
without knowing that info, i (nor anyone else, for that matter) can't tell you what you need to know.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 04-02-2006, 01:14
neo's Avatar
neo neo is offline
whoa.
AKA: Dan Murrow
FRC #0585 (THS CyberPenguin Robotics)
neo has a spectacular aura aboutneo has a spectacular aura about
chain drive with a cim motor. easy stuffs if you have something to house the wheels.
Unread 04-02-2006, 01:31
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Try using the kit gearbox with only one stage of gearing. And then go sprocket and chain to the kit wheel(s). You can even use the kit frame. You can make a ball shooter fairly simply and fairly effectively using only the parts in the kit.
Unread 04-02-2006, 02:11
dtengineering's Avatar
AKA: Jason Brett
For a single wheel shooter, just mount the CIM directly to a 3/4" shaft with the 8" skyway wheels pressed onto the shaft. You can do this by grinding a flat spot on the CIM drive shaft, then drilling an appropriately sized hole in one end of the 3/4" shaft, and drilling and tapping for a couple of set screws to hold the motor's drive shaft firmly in place.
Add a couple pieces of plywood, with some bearings pressed into them, and you are halfway there.
Direct drive worked great on our prototype.... and we're using it for our final version. Albeit with a FP motor rather than the CIM... those are on our drive train.
Jason
Unread 05-02-2006, 21:04
jimwick's Avatar
jimwick jimwick is offline
jim wick
FRC #0885 (the Green Team)
jimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of light
We've had some luck with direct drive. To connect the motor and wheel use a heavy rubber tube to connect the shafts. This provides isolation, corrects misalignment, usually can transmit enough torque for this application. Fuel line hose is a good option.
612's ball launcher - prototype jskene Robot Showcase 8 05-02-2006 11:22
White Paper Discuss: Physics Analysis of a Ball Launcher coastertux Extra Discussion 0 01-02-2006 17:58
Second FIRST Ball Launcher generalbrando Technical Discussion 14 13-01-2006 09:08
Poll: What kind of ball launcher do you have Rickertsen2 Technical Discussion 3 12-01-2006 23:13
First FIRST ball launcher? Rick TYler Technical Discussion 13 10-01-2006 22:42
