Re: Motor Limits
Two came in the kit this year.
You have to hook them up to the digital inputs on the RC. Make sure your programmer sets them right in the code and your electrician wire them up correctly and you should be set. Last edited by ForgottenSalad : 04-02-2006 at 02:14. |
Re: Motor Limits
Heh, Im not only the driver, but the only programmer we have. I am also the youngest on the team, 15..
We arn't meeting til Monday so I wont be able to check it out till later. We may need like 2 more, for our gate. Or mayeb we can somehow just make sure we dont hit it farther then needed Saves some money. Since we have a team of 10. Ya need all the help and money you can get, hehe.Thanks for all the quick replys! So has anyone set up their algorithm for the gun yet? |
Re: Motor Limits
As far as saving money goes, I'm pretty sure you can get them at radioshack for a pretty cheap price. On a different note, good luck with your robot this year! I hear "turret" and "gate" in your posts... I draw that you might be going for both...
Re: Motor Limits
gate meaning the side goals? That wasn't what I was reffering to. But our end robot will be able to push a ball or two in there if needed. The gate I was reffering to was the motor that opens and shuts the opening for the balls dropping into the gun. Because you dont want to make a shot from accross the field... thatd be ridiculous
... but cool if we made it.Were definatly getting closer, our teacher is getting nervous that we wont finish it, heh. Ill check radioshack on Monday or tomorow if I am by there see if they have them. Thanks. |
Re: Motor Limits
Heh, our local radioshack appearantly doesn't stock them though I could swear I've seen them there before. I don't know if yours will, I haven't checked the website if any of the stores stock them.
