Go to Post before you post, ask yourself: Is there a good reason to post this? - Jeff Waegelin [more]
Unread 28-01-2006, 11:13
cmurdoch cmurdoch is offline
AKA: Caroline Murdoch
FRC #1208 (Metool Brigade)
cmurdoch is on a distinguished road
Problems Combining Camera Code and Driving Code
I have both the camera code and the driving code working independently , but I've been having some trouble combining them. I've added both user_SerialDrv.c and user_SerialDrv.h to the camera code and uncommented the IFI code in user_routines.c as well as in user_routines_fast.c. I've also tried to change the pwm output assignments of either our two drive motors or the camera servos. When I left the servos on pwm01 and pwm02 and changed the pwms for the motors the camera worked and the driving didn't. When I switched them the driving worked and the camera didn't, in fact, the camera just sat there and twitched. Then, I assigned the servos to pwm01 and pwm02 and the motors to pwm05 and pwm06. The camera froze in home position and the driving worked for about 30 seconds before halting and displaying a code error. If anyone has any idea how I can fix this I'd really appreciate it.
Thanks
Unread 28-01-2006, 12:33
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Problems Combining Camera Code and Driving Code
Thanks
user_SerialDrv.c/.h will conflict with the serial port driver included with the camera code (this is documented in serial_ports_readme.txt). At the very least, you'll need to remove user_SerialDrv.c/.h.
-Kevin
Kevin Watson
http://kevin.org
Unread 29-01-2006, 14:41
Steve Orr's Avatar
Steve Orr Steve Orr is offline
iusorr
FRC #1293 (D5Robotics)
Steve Orr is an unknown quantity at this point
Send a message via AIM to Steve Orr Send a message via Yahoo to Steve Orr
I'm kind of in the same boat, and will be working on combining them this week. If I discover the secrets, I'll post...
I'll be eager to see if you find anything out as well!
S.Orr
D5Robotics : Team 1293
Irmo, SC
Unread 29-01-2006, 18:49
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
I see two likely problems with what you are doing:
(1) As Kevin says, the camera's serial code needs serial.c and serial.h from his code, and not the user_SerialDrv.c/h. You need to remove those from the project.
(2) Similarly, Kevin's serial code requires the interrupt routines in user_routines_fast.c to be correct (if you don't have this correct, you'll get the red light of death). If you aren't using other special interrupt code (encoders or the gyro), just copy user_routines_fast.c from Kevin's camera code and try that. Otherwise, you'll have to make sure all the appropriate interrupt handlers are in place for all the codes you are using. This can be done, our bot's testbed code now has the camera, gyro, shaft encoders, and two additional ADC channels running at the same time, but it's tricky and requires careful reading of the adc_readme.txt, encoder_readme.txt, camera_readme.txt, etc. (And we didn't get it right the first time, as you can see if you look the other places I've posted).
Unread 29-01-2006, 18:57
FRC #2429
Was there any problems with the documentation that caused it to not work the first time? If so, what was it?
-Kevin
Kevin Watson
http://kevin.org
Unread 29-01-2006, 19:10
kaszeta's Avatar
As far as I can tell, the documentation is fine and the problems were on our end (not saving .tmp_data one time, and neglecting to insert the timer2 interrupt another time, both of which were clearly noted in the readme files), so if one makes sure they follow the instructions carefully it should work.
Unread 02-02-2006, 20:35
Thanks
The problem was definately with SerialDrv.c/.h I didn't have problems with user_routines_fast.c because I started with the camera code and adapted that for driving. Thanks for all your help. It works wonderfully now and the next challenge is getting the camera to track using the motor on our rotating turret. Thanks again and thanks for all the great code Kevin. You rock.
Unread 04-02-2006, 13:02
1594code 1594code is offline
FRC #1594
1594code is an unknown quantity at this point
Thanks for sharing all this information-- it's been helpful.
We have followed the serial_ports_readme instructions, we're using Kevin's camera code user_routines_fast.c interrupt handlers, and we tried to remove user_serial_drv.c.
We had a problem with this last action-- the function breaker_tripped was called in user_routines.c, and it is declared in User_serial_drv.c, so we can't compile
Has this happened to anyone else? What did you do?
Unread 04-02-2006, 13:06
FRC #2429
If you aren't using the breaker panel, you can safely delete the function and user_serial_drv.c/.h from your project.
-Kevin
Kevin Watson
http://kevin.org
Unread 04-02-2006, 14:35
FRC #1594
-Kevin
Thank you for your reply! We have yet another question... We are using four circuit breakers: the maxi style circuit breaker panel, the 120 Hi-Amp circuit breaker, and two other circuit breaker panels that came with the KOP.
Is the circuit breaker you meant among those four?
Unread 04-02-2006, 14:56
FRC #2429
No, "breaker panel" refers to the circuit breaker panel distributed last year to teams. It sends out serial data to inform the robot controller that a breaker has tripped.
-Kevin
Kevin Watson
http://kevin.org
Unread 04-02-2006, 17:31
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
When combining the camera and interrupt code, how many timer interrupts are required? Any other details? So far I'm still getting the RLOD!!!!
Jon Mittelman
Team236
Unread 04-02-2006, 17:51
kaszeta's Avatar
You should need an interrupt handler for tx1, rx1, tx2, and rx2, unless you are also using encoders, the adc code, or the gyro (which uses the adc code).
We do use all of those, and it's working fine. Here's our InterruptHandlerLow:
#pragma code
#pragma interruptlow InterruptHandlerLow save=PROD,section(".tmpdata")
void InterruptHandlerLow(void)
	unsigned char Port_B;
	unsigned char Port_B_Delta;
	if(PIR1bits.RC1IF && PIE1bits.RC1IE) // rx1 interrupt?
		#ifdef ENABLE_SERIAL_PORT_ONE_RX
		Rx_1_Int_Handler(); // call the rx1 interrupt handler (in serial_ports.c)
		#endif
	else if(PIR3bits.RC2IF && PIE3bits.RC2IE) // rx2 interrupt?
		#ifdef ENABLE_SERIAL_PORT_TWO_RX
		Rx_2_Int_Handler(); // call the rx2 interrupt handler (in serial_ports.c)
		#endif
	else if(PIR1bits.TMR2IF && PIE1bits.TMR2IE) // timer 2 interrupt?
		PIR1bits.TMR2IF = 0; // clear the timer 2 interrupt flag [92]
		Timer_2_Int_Handler(); // call the timer 2 interrupt handler (in adc.c)
	else if(PIR1bits.ADIF && PIE1bits.ADIE) // ADC interrupt
		PIR1bits.ADIF = 0; // clear the ADC interrupt flag
		ADC_Int_Handler(); // call the ADC interrupt handler (in adc.c)
	else if (INTCON3bits.INT2IF && INTCON3bits.INT2IE) // encoder 1 interrupt?
		INTCON3bits.INT2IF = 0; // clear the interrupt flag
		#ifdef ENABLE_ENCODER_1
		Encoder_1_Int_Handler(); // call the left encoder interrupt handler (in encoder.c)
		#endif
	else if (INTCON3bits.INT3IF && INTCON3bits.INT3IE) // encoder 2 interrupt?
		INTCON3bits.INT3IF = 0; // clear the interrupt flag
		#ifdef ENABLE_ENCODER_2
		Encoder_2_Int_Handler(); // call right encoder interrupt handler (in encoder.c)
		#endif
	else if (INTCONbits.RBIF && INTCONbits.RBIE) // encoder 3-6 interrupt?
		Port_B = PORTB; // remove the "mismatch condition" by reading port b
		INTCONbits.RBIF = 0; // clear the interrupt flag
		Port_B_Delta = Port_B ^ Old_Port_B; // determine which bits have changed
		Old_Port_B = Port_B; // save a copy of port b for next time around
		if(Port_B_Delta & 0x10) // did external interrupt 3 change state?
			#ifdef ENABLE_ENCODER_3
			Encoder_3_Int_Handler(Port_B & 0x10 ? 1 : 0); // call the encoder 3 interrupt handler (in encoder.c)
			#endif
		if(Port_B_Delta & 0x20) // did external interrupt 4 change state?
			#ifdef ENABLE_ENCODER_4
			Encoder_4_Int_Handler(Port_B & 0x20 ? 1 : 0); // call the encoder 4 interrupt handler (in encoder.c)
			#endif
		if(Port_B_Delta & 0x40) // did external interrupt 5 change state?
			#ifdef ENABLE_ENCODER_5
			Encoder_5_Int_Handler(Port_B & 0x40 ? 1 : 0); // call the encoder 5 interrupt handler (in encoder.c)
			#endif
		if(Port_B_Delta & 0x80) // did external interrupt 6 change state?
			#ifdef ENABLE_ENCODER_6
			Encoder_6_Int_Handler(Port_B & 0x80 ? 1 : 0); // call the encoder 6 interrupt handler (in encoder.c)
			#endif
	else if(PIR1bits.TX1IF && PIE1bits.TX1IE) // tx1 interrupt?
		#ifdef ENABLE_SERIAL_PORT_ONE_TX
		Tx_1_Int_Handler(); // call the tx1 interrupt handler (in serial_ports.c)
		#endif
	else if(PIR3bits.TX2IF && PIE3bits.TX2IE) // tx2 interrupt?
		#ifdef ENABLE_SERIAL_PORT_TWO_TX
		Tx_2_Int_Handler(); // call the tx2 interrupt handler (in serial_ports.c)
		#endif
Unread 05-02-2006, 09:51
Jon236's Avatar
AKA: Jon Mittelman
#pragma code
		#endif
		#endif
		#endif
		#endif
			#endif
			#endif
			#endif
			#endif
		#endif
		#endif
I've made all of those changes and still get the RLOD. We use the interrupts, timers, rx1&2 tx1&2.
Any other thoughts?
Jon
Unread 05-02-2006, 10:59
kaszeta's Avatar
Any other thoughts?
Jon
Any more of your code you can share with us (the rest of user_routines_fast.c, for example)?
What is wrong with this code???? It won't Compile and I don't know why? Please Help CrashZero Programming 23 26-03-2004 09:44
