Go to Post I haven't invented anything for an hour or two. I need to get back to work. - MrForbes [more]
Unread 04-02-2006, 14:53
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
Can we use last years CIM's?
I am a bit confused on if we are allowed to use last years CIM motors. It's a noob question I know. Also there are 2 different kinds of CIM motors (2 of each) in the KOP this year right?
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Unread 04-02-2006, 15:19
Billfred's Avatar
Billfred Billfred is offline
Re: Can we use last years CIM's?
Yes and yes. Read the Robot section of the manual.
Unread 04-02-2006, 15:31
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
can we use 2 of the older one and 2 of the 06' ones? No belt drives. What's the regulation?
I read <R25>, but I still don't understand
Callsign: N6ARA
Unread 04-02-2006, 19:17
GaryVoshol's Avatar
Cogito ergo arbitro
You can use the two new large CIMS you got this year. You can use the two smaller CIMS you got this year. And you can use two additional smaller CIMS from previous years, as long as they are identical to the ones you got this year. Total of 6 big heavy motors, if that's what you need.
Unread 04-02-2006, 20:51
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
I know there are 2 different cim output bars. One of them are the bars with teeth, and on that is a solid bar. either one goes right?
Callsign: N6ARA
Unread 04-02-2006, 21:14
Simon Strauss's Avatar
Simon Strauss Simon Strauss is offline
None #1155 (Sciborgs)
Simon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant future
Send a message via AIM to Simon Strauss
The shaft type on the old cim motors doesn't need to be the same as that on the new small cim as the motor itself has the same model number on it. i know in my team's case one set had a key slot with the ends rounded off while the other had a continuous slot and they were both the same type of motor. as for what you mean about bars with teeth i have no idea what you're talking about id follow Billfred's advice and at least take a look at the pictures for the KOP that is in the robot section this year.
NYC Chairmen's Award Winners 2007 Thank you team 2265, you were our project and we couldnt have done it without you all
New Jersey Regional Finalists thanks to teams 359 and 486 Aloha
"Beware of the Ska Robot Army!" -The Aquabats
Unread 05-02-2006, 01:14
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
I took a look at the KOP list and they are 2 keyed ones. I think there were 2 keyed ones last year right??
Callsign: N6ARA
Unread 05-02-2006, 01:22
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
2002 motors were not a round keyed shaft. They were a very stange splined shaft. You cannot legally use them this year. 2003 and up CIM motors have a keyed shaft. The length and exact shape of the keyway has changed slightly over the years, but you may use 2003 and up CIM motors. You may have up to 4 small CIMs and 2 large CIMs (minibike motor) on the 2006 robot.
Unread 05-02-2006, 01:59
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Awesome, thanks so much
Callsign: N6ARA
What will this year's topic be? team384_pat 3D Animation and Competition 20 09-12-2003 18:31
Championship Qualification - How you would've done it Ken Leung Championship Event 6 26-10-2003 14:00
What changes to this year's game...? DougHogg General Forum 16 20-04-2003 15:35
Thoughts on this years competition... archiver 2001 3 24-06-2002 01:11
What have you done in past years? Lora Knepper Chairman's Award 3 03-06-2001 18:23
