Go to Post Please ask yourself..."If my robot is on fire and the pneumatics are randomly activating, is my main breaker someplace that I want to put MY hand?" - Jaxom [more]
Unread 04-02-2006, 15:20
Conan Conan is offline
FRC #1137
Conan is an unknown quantity at this point
Problems with the gyro
Our team is having problems with our gyro. We are using the KOP gyro with Kevin Watson's gyro code. I'm pretty sure everything's been implemented properly. We tried to just compile the code that Kevin provided, and the output results don't make sense.
The gyro_angle output starts are zero. What happens from there varies. I haven't been able to find a definate pattern. Sometimes when we turn it the output displays exactly what we feel it should. However, other times, the results don't make any sense. We might turn the gyro (slowly), and the gyro_angle does not change at all, while sometimes we can set the gyro down on a table and the gyro_angle goes wild and gives random values.
We can't really pinpoint the cause of the problem, but if any of you have encountered anything close, please share. Thanks for all of your help.
Unread 04-02-2006, 15:29
Re: Problems with the gyro
erratic behaviour sounds like a bad connection between the gyro and either the power, or the analog signals to the RC.
The signals are analog, and you have to make sure you dont corrupt them, like tie-wrapping them to the power leads for the motors or other wires carrying heavy current.
Also make sure the gyro is getting the correct voltage on its power pins.
also, are you sure you are turning the gyro on the right axis? it only senses rotation on one axis.
Unread 04-02-2006, 16:38
FRC #1137
When the terminal output indicates that the gyro is in fact turning, then yes, the voltage changes appropriately. However, the voltage doesn't always change when the gyro is turned, and the output on the terminal supports this. Also, there is no interference with other high-current wires becase the gyro and controller are temporarily disconnected from the robot.
Also, we looked at the documentation about the gyro, and when we rotate it about the axis normal to the specifications, the gyro angle did not change. However, when we rotated it along a different axis, the gyro angle would change. But once more, this change is not always the correct angle.
Would you recommend trying out a new gyro? If so, are there any good recommendations?
Unread 04-02-2006, 17:23
do you have a way to look at the voltage coming out of the gyro board?
that would isolate the problem: is the sensor output working correctly?
is the ADC input channel on the RC working correctly (have you tried a different input channel on the RC?)
is your code reading the input all the time, or maybe some other function in the code is interfering with the gyro input routine?
Unread 04-02-2006, 18:24
FRC #1137
Well, yes, we did measure the voltage at the gyro board. This gives us the right voltage values, but not neccessarily at the right times. The voltage values at the gyro board matches up with the terminal output, but neither match up with the motion of the gyro.
I tried attaching the gyro to other analog inputs. I must be doing this wrong (or the gyro is broken). In Kevin's code, the only part I should change to switch the analog input port is the #define in gyro.h, right? I tried switching this from "1" to "2", and now there is NO output. The same thing happened on input port 3.
Lastly, there should not be a section of code that is conflicting. Once again, we are using Kevin's code. These problems occur when there are no modifications whatsoever to Kevin's code.
EDIT: While researching all we could, we finally came across the documentation that said the YRG is silkscreened incorrectly. So, our white wire and red wire were swapped on the gyro. We're done working for the day, but tomorrow we'll swap these two, and see if the gyro works (hopefully we haven't blown it). We'll post back tomorrow with an update. Thanks for all of your help.
Unread 04-02-2006, 19:48
Kevin Watson's Avatar
La Caņada High School
FRC #2429
It didn't work because the ADC software, by default, only samples one channel. If you move the gyro to ADC channel 2, you'll need to edit adc.h to sample at least two channels.
-Kevin
Kevin Watson
http://kevin.org
Unread 06-02-2006, 01:17
FRC #1137
Well, earlier today, we switched around the red and white wires, and now the gyro works wonderfully. Thanks for all of your help, and Kevin, we'll take that into consideration if we add any more analog input devices.
Unread 06-02-2006, 01:45
Chriszuma's Avatar
Chriszuma Chriszuma is offline
Jack of all trades
AKA: Chris Hammond
FRC #0068 (Truck Town Thunder)
Chriszuma is just really niceChriszuma is just really niceChriszuma is just really niceChriszuma is just really nice
Send a message via AIM to Chriszuma
this is why reading the documentation is vital.
2006 T3 World Tour: Great Lakes - Waterloo - Palmetto - IRI
2006 Awards: Motorola Quality - RadioShack Innovation in Control
My website: http://zuma.phire.org/
Truck Town Thunder's website: http://trucktownthunder.com/
Gyroscope Code Kevin Watson Programming 65 01-03-2008 23:46
Yaw Rate Gyro Problems RetroKamikaze Programming 3 27-01-2006 20:55
Updated: Example Gyro Interface Code Kevin Watson Programming 2 28-03-2005 04:36
Example gyro code released. Kevin Watson Programming 60 17-03-2005 18:32
Wierd gyro code problems...pls help Salik Syed Programming 4 14-03-2004 01:29
