Go to Post "If a student CAN do it, a student SHOULD do it." - Mr. Lim [more]
  #91   Spotlight this post!
Unread 03-02-2006, 17:23
darkstar's Avatar
darkstar darkstar is offline
Animator
FRC #0585 (Warrior Robotics)
darkstar is an unknown quantity at this point
Send a message via Yahoo to darkstar
Re: 3D Animation Q/A
Do you guys know how to export something from adobe preimere pro 2 to quicktime, with out the video looking super blury?
  #92   Spotlight this post!
Unread 03-02-2006, 19:10
Damelvin's Avatar
Damelvin Damelvin is offline
Damelvin
AKA: J.D.
FRC #1147 (Herdinators)
Team Role: Animator
Damelvin is an unknown quantity at this point
Send a message via AIM to Damelvin Send a message via Yahoo to Damelvin
Originally Posted by Capt.ArD
for the entry form, there is a line on the the form where you write the name of the song and artist. be sure to include a copy of a paper that gives you permission to use copyrighted material with the forms.
for the glass, turn up the specular level and the glossiness of the material. that will help a lot.
for the screen thing, you can use a gif or an avi file as a moving texture for whatever happens on the screen. for a glow, use a omni light with the glow and ray lens effects on it. put it inside the monitor so it won't show, then pull it out whe you want the glow to show.
for the vortex, use a tube with a cool swierly texture on it, and hide it inside the monitor, only to expand it when the time comes for much vortex-pwning.
i had written a better tutorial on this, but my computer messed up on me, so if you need a better explaination, let me know an ill type it up again.
What I meant for the music is how would I put non copyrighted songs in the paper work or should I jsut say it was created for my animation. THese songs are NOT COPYRIGHTED, so i shouldn't need any paper work.
Ill try that on teh glass.
I want the screen black then it glows in the middle, but then opens up or swirls towards teh center and opens into teh vortex anyway tyo get the swirl effect or a black hole effect?
Would there be an easy way to have alot of colors flashing or would I have to individual set the each light and color change?
Hear about the cannibal that passed his brother in the forest.
  #93   Spotlight this post!
Unread 03-02-2006, 19:13
BuddyB309's Avatar
BuddyB309 BuddyB309 is offline
I freaking love animating!!
AKA: Peter Casey
FRC #1625 (Winnovation)
Team Role: Animator
BuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond repute
Send a message via AIM to BuddyB309
render it at a large format like 740X680 or whatever the requirements are. when you save it as an avi file and click save, the little menu that pops up make sure to go under the tab and choose "no compression." that should do the trick.
A.K.A Llama
check out my latest animations Appliance Night Out, Infant Intolerable, Fishing Like a Loony Tune, VVV Roadside Assistance
Life? I have a life. It is sitting at my computer and Animating. AND DRAWING!!! WEEEEEEE!!!!
  #94   Spotlight this post!
Unread 03-02-2006, 19:32
Capt.ArD Capt.ArD is offline
Animator
FRC #0116 (Epsilon Delta)
Team Role: Animator
Capt.ArD will become famous soon enoughCapt.ArD will become famous soon enough
k sorry, i saw that just after i posted. ur right, if it's not copyrighted, then it's fine. no worries.
so this vortex, is it within the screen, like an image, or does it come out of the screen? that is still unclear.
for the dot that begins to swirl, easiest way would be an avi texture. i actually can't think of a way to do it other than that. do you have flash to make a swirly thing with? sorry i can't help more than that.
  #95   Spotlight this post!
Unread 03-02-2006, 19:40
Damelvin's Avatar
Damelvin
AKA: J.D.
Team Role: Animator
Pretty much the picture I want to get acrross is the monitor is opening you to inside the computer or inside teh internet and its pulling you in. Then the vortex will take you a TRON looking place where are robot is. This all happens once the monitor screen fills up the whole viewpoint.
  #96   Spotlight this post!
Unread 04-02-2006, 01:19
Damelvin's Avatar
Damelvin
AKA: J.D.
Team Role: Animator
I am trying to add a material to a wall and a took a picture of my wall just to mess with and I noticed the little bumps in the wall are huge and I trying tiling it done and then I get this darken colored lines taht go through the picture. Anyway for these to go away or do I have to get a wider shot of the wall picture I took?
  #97   Spotlight this post!
Unread 04-02-2006, 12:59
darkstar's Avatar
Animator
Do you guys know how to add adio by chance?
  #98   Spotlight this post!
Unread 04-02-2006, 13:39
Animator
Team Role: Animator
sounds like you took a picture too close to the wall. the dark lines are probably unequal shadows in the picture. try retaking the picture with good direct lighting on it.
ok, if the monitor is going to fill up the whole screen before it starts moving, then just use a avi for a texture. no other effects necessary.
  #99   Spotlight this post!
Unread 04-02-2006, 15:31
darkstar's Avatar
Animator
I don't why, but each time i use adobe priemere pro 2 make a video the text i made in 3d max comes up blurry. Does anyone have any suggestions to clear up?
  #100   Spotlight this post!
Unread 04-02-2006, 15:54
Animator
Team Role: Animator
I don't know anything about adobe premier. sorry.
does anyone know if we can subit our animation only once per competition, or only once total. our team is registered to go to two competitions, so can i submit to both, or must i pick 1?
  #101   Spotlight this post!
Unread 04-02-2006, 16:13
darkstar's Avatar
Animator
It's one video per team is what I understand, but you might want to post that on the question and answer system on the FIRST website.
  #102   Spotlight this post!
Unread 04-02-2006, 17:27
Damelvin's Avatar
Damelvin
AKA: J.D.
Team Role: Animator
DO you mean like for your title part and your credit parts? Or actual models that are letters in the animation?
  #103   Spotlight this post!
Unread 04-02-2006, 17:29
xrabohrok's Avatar
xrabohrok xrabohrok is offline
hunter of errors
FRC #1208 (The Metool Brigade)
xrabohrok is an unknown quantity at this point
How do I stop selecting a selection class? It just won't stop!
"It's programming's fault" may be a viable excuse for just about everything, except the robot falling apart.
It will 'cause it can!
constants aren't. variables won't.
  #104   Spotlight this post!
Unread 04-02-2006, 19:47
BuddyB309's Avatar
AKA: Peter Casey
Team Role: Animator
You upload the video twice and put the same video into the two different competitions you are going to.
A.K.A Llama
  #105   Spotlight this post!
Unread 04-02-2006, 19:52
BuddyB309's Avatar
AKA: Peter Casey
Team Role: Animator
1 of two things if its is blurry in the viewing screen in the program when you are putting it together just hit enter.
If the final product looks blurry it is probably the way you set it up. Exporting it as uncompressed first and if that doesn't work try to set it up as a different layer.
A.K.A Llama
Animation Question Velaes 3D Animation and Competition 15 02-02-2005 00:11
FANATIC - Offseason Animation Competition opnickc 3D Animation and Competition 15 10-06-2004 20:54
A solution for Animation Judging for 2005 TKatsAniMentor 3D Animation and Competition 26 04-04-2004 15:29
A joke they called Regional Animation Competitions Lev 3D Animation and Competition 50 18-03-2003 21:18
How to develop your animation idea and keep your sanity too! Robby O 3D Animation and Competition 0 25-01-2002 01:25
