Re: Improved IFI Wheels
Basically it is meant to strenghten the integrity of the wheels.
I'm curious if anyone has had problems with these wheels? Our screws kept backing out even after loctite and good torques. They don't seem to handle the shear/vibration happening when getting torqued. They also seem to flex enough to cause chain misalignments under hard turns. Last night we had to take all the roller bearings out of them and make long brass bushings to go all the way through the wheels as our 3/8" shafts kept bending and we completely smashed the roller bearings in 1 wheel. So far this has solved the flexing problems but I don't like riding on brass bearings. I think They're a great idea, but their modularity may be a serious weakness. I hope I'm wrong and we're just having bad luck.
What Loctite did you use. If it was the blue (low strength) then yes they still back out, but they should be good with the red (high strength) loctite.
As for the wheels deforming and causing chain miss alignment we have never had that issue, even with hard turns. |
| TO much traction??? (ifi wheels or AM wheels) | Heretic121 | Technical Discussion | 9 | 04-02-2006 12:09 |
| pic: Team 229's Anodized IFI Wheels | Adrienne E. | Extra Discussion | 11 | 23-01-2006 17:55 |
| Improved Mecanum Wheels | techtiger1 | Technical Discussion | 23 | 08-10-2005 01:02 |
| Lots of Wheels and F = u x N | archiver | 2001 | 17 | 23-06-2002 23:37 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
