Go to Post I think that FIRST should just give up and officially recognize Chiefdelphi as the place to go for community and team resources. - Greg Needel [more]
Unread 04-02-2006, 17:45
Joe Hershberger Joe Hershberger is offline
National Instruments
AKA: jhersh
FRC #2468 (Appreciate)
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
Re: New version of WPILib
Originally Posted by BradAMiller
There is another new version of WPILib that has the following changes:
1. The capture camera packet functions now have a one second timeout. If the timeout happens, then zeros are returned for all data.
2. A bug in the servo control code was fixed where it was sending bad values when the middle digit was zero in a three digit servo value.
3. There are functions to read the backup and main battery voltages.
You can get it from my website and following the links to the software. As always please post any problems that you might encounter.
Brad,
I'm attempting to compile a student's program that was written and exported from EasyC. I don't have EasyC and as such I'm using MPLab and your library to build the project. Everything goes well until the link step. It then notifies me that the "Coff file format is out of date" for the objects in the lib file. It wants to rebuild the library, but I obviously don't have the source. Naturally, Microchip changed their coff format with the new version of their compiler. I'm using version 3.01 of the compiler, which comes with version 4.01 of the linker. Can you post the source to the library so it can be rebuilt? If not, what version are you using to build the library so I can downgrade?
Thanks,
-Joe
Welcome to the WPILib forum BradAMiller Programming 22 25-03-2008 22:44
WPILib - Library for robot programming BradAMiller Programming 7 21-06-2006 03:12
openFIRST Project Announces Pending Deadline for End of Support for Old Versions Timothy D. Ginn FIRST-related Organizations 0 11-07-2005 22:40
Flash Version of Playing Field Conor Ryan General Forum 49 30-01-2005 20:08
Does anyone know if we can use the version of Backburner from the 3DSMax trial ver? lnxpenguin4ever 3D Animation and Competition 2 26-01-2005 19:58
