Go to Post One of my early mentors gave me wise words -- when designing a system to compile & analyze information, your first design choice should always include consideration of a stack of 3x5 file cards. - Jaxom [more]
Unread 04-02-2006, 17:51
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Re: Problems Combining Camera Code and Driving Code
Originally Posted by Jon236
When combining the camera and interrupt code, how many timer interrupts are required? Any other details? So far I'm still getting the RLOD!!!!
You should need an interrupt handler for tx1, rx1, tx2, and rx2, unless you are also using encoders, the adc code, or the gyro (which uses the adc code).
We do use all of those, and it's working fine. Here's our InterruptHandlerLow:
#pragma code
#pragma interruptlow InterruptHandlerLow save=PROD,section(".tmpdata")
void InterruptHandlerLow(void)
	unsigned char Port_B;
	unsigned char Port_B_Delta;
	if(PIR1bits.RC1IF && PIE1bits.RC1IE) // rx1 interrupt?
		#ifdef ENABLE_SERIAL_PORT_ONE_RX
		Rx_1_Int_Handler(); // call the rx1 interrupt handler (in serial_ports.c)
		#endif
	else if(PIR3bits.RC2IF && PIE3bits.RC2IE) // rx2 interrupt?
		#ifdef ENABLE_SERIAL_PORT_TWO_RX
		Rx_2_Int_Handler(); // call the rx2 interrupt handler (in serial_ports.c)
		#endif
	else if(PIR1bits.TMR2IF && PIE1bits.TMR2IE) // timer 2 interrupt?
		PIR1bits.TMR2IF = 0; // clear the timer 2 interrupt flag [92]
		Timer_2_Int_Handler(); // call the timer 2 interrupt handler (in adc.c)
	else if(PIR1bits.ADIF && PIE1bits.ADIE) // ADC interrupt
		PIR1bits.ADIF = 0; // clear the ADC interrupt flag
		ADC_Int_Handler(); // call the ADC interrupt handler (in adc.c)
	else if (INTCON3bits.INT2IF && INTCON3bits.INT2IE) // encoder 1 interrupt?
		INTCON3bits.INT2IF = 0; // clear the interrupt flag
		#ifdef ENABLE_ENCODER_1
		Encoder_1_Int_Handler(); // call the left encoder interrupt handler (in encoder.c)
		#endif
	else if (INTCON3bits.INT3IF && INTCON3bits.INT3IE) // encoder 2 interrupt?
		INTCON3bits.INT3IF = 0; // clear the interrupt flag
		#ifdef ENABLE_ENCODER_2
		Encoder_2_Int_Handler(); // call right encoder interrupt handler (in encoder.c)
		#endif
	else if (INTCONbits.RBIF && INTCONbits.RBIE) // encoder 3-6 interrupt?
		Port_B = PORTB; // remove the "mismatch condition" by reading port b
		INTCONbits.RBIF = 0; // clear the interrupt flag
		Port_B_Delta = Port_B ^ Old_Port_B; // determine which bits have changed
		Old_Port_B = Port_B; // save a copy of port b for next time around
		if(Port_B_Delta & 0x10) // did external interrupt 3 change state?
			#ifdef ENABLE_ENCODER_3
			Encoder_3_Int_Handler(Port_B & 0x10 ? 1 : 0); // call the encoder 3 interrupt handler (in encoder.c)
			#endif
		if(Port_B_Delta & 0x20) // did external interrupt 4 change state?
			#ifdef ENABLE_ENCODER_4
			Encoder_4_Int_Handler(Port_B & 0x20 ? 1 : 0); // call the encoder 4 interrupt handler (in encoder.c)
			#endif
		if(Port_B_Delta & 0x40) // did external interrupt 5 change state?
			#ifdef ENABLE_ENCODER_5
			Encoder_5_Int_Handler(Port_B & 0x40 ? 1 : 0); // call the encoder 5 interrupt handler (in encoder.c)
			#endif
		if(Port_B_Delta & 0x80) // did external interrupt 6 change state?
			#ifdef ENABLE_ENCODER_6
			Encoder_6_Int_Handler(Port_B & 0x80 ? 1 : 0); // call the encoder 6 interrupt handler (in encoder.c)
			#endif
	else if(PIR1bits.TX1IF && PIE1bits.TX1IE) // tx1 interrupt?
		#ifdef ENABLE_SERIAL_PORT_ONE_TX
		Tx_1_Int_Handler(); // call the tx1 interrupt handler (in serial_ports.c)
		#endif
	else if(PIR3bits.TX2IF && PIE3bits.TX2IE) // tx2 interrupt?
		#ifdef ENABLE_SERIAL_PORT_TWO_TX
		Tx_2_Int_Handler(); // call the tx2 interrupt handler (in serial_ports.c)
		#endif
What is wrong with this code???? It won't Compile and I don't know why? Please Help CrashZero Programming 23 26-03-2004 09:44
