Go to Post Ah, this sounds like a sitcom whose pilot I should write and send to NBC - "Life With Lavery". There's a lot of eating, several practical jokes, and lots of bad hair. - Amanda Morrison [more]
Unread 04-02-2006, 18:10
Goldeye Goldeye is offline
AKA: Josh Hecht
FRC #0694 (Stuypulse)
Goldeye has a spectacular aura aboutGoldeye has a spectacular aura aboutGoldeye has a spectacular aura about
Send a message via AIM to Goldeye
Re: Gear tooth sensor / GTS on DIO 3,4,5,6?
I'm assuming your issue is accessing which of the interrupts 3-6 went off. If not, sorry -_-
Take a look at Kevin Watson's interrupt tutorial. It gives well annotated code for initializing and using all the interrupts. There is a way to use all 6 pins seperately, all though you need to use the method he does.
However, you need to convert it to use the files for the new RC.
Replace the #include <ifi_picdefs.h> with #include <p18cxxx>, replace the linker file with the 18c8722.lkr from this year's default code, and change MPLAB's project options to build using the P18C8722 as the processor.
Team 694
2005 Championship - Galileo Semifinalist
2005 New York - Regional Chairmans Award
2005 New York - Semifinalist (Thanks 1257,1340)
Will the gear tooth break? sanddrag Technical Discussion 11 23-01-2006 14:24
Gear Tooth Sensor AMIRAM Electrical 2 22-01-2006 04:09
Gear tooth sensor vs. Optical Encoders Avarik Programming 7 17-01-2006 10:18
Accelerometer vs Gear Tooth Sensors zdeswarte Electrical 4 22-01-2005 15:35
gears Michael Leicht Inventor 12 16-09-2004 10:52
