Go to Post You wake up at 2:54 am and aren't even mad bc robots - fargus111111111 [more]
Unread 04-02-2006, 18:53
Re: Motors and the High Port Numbers
Our lead programmer wrote his own PID code. In testing, nothing worked right using the high PWM ports. He used Generate_Pwms, too. When we moved the control to PWM 3 & 4, it started working. No worries, it only cost us a day...
Unread 04-02-2006, 19:20
Gdeaver Gdeaver is offline
FRC #1640
Check me but the lower PWM ports are controlled by the master proc. the high ones are software generated by the user proc. Interrupts are almost guaranteed to affect the upper PWM ports.
Unread 04-02-2006, 19:38
Jared Russell's Avatar
Taking a year (mostly) off
We've had some wacky stuff happen on ports 13-16. I would recommend forgoing them altogether.
Unread 04-02-2006, 19:41
So, if we are using encoders, which use interrupts, to control speed on the four high PWM ports, which are interrupt-sensitive, we aren't just shooting ourselves in the foot, but actually firing an M16 on full auto directly into our arch, right?
Unread 04-02-2006, 21:22
Just say no to PWMS 13-16.
Never used them, never will.
They seemed like a good idea at the time...
Unread 04-02-2006, 21:38
We've been using pwm16...
...for camera power.
Unread 04-02-2006, 21:39
Guilty
Unread 04-02-2006, 21:43
I've been reading that the camera is intended to run off the backup battery. Do the PWM ports provide the right voltage for the, you know, camera?
Unread 04-02-2006, 21:58
The servo power on the pwm output pins comes from the backup battery.
Goldeye Goldeye is offline
AKA: Josh Hecht
FRC #0694 (Stuypulse)
Goldeye has a spectacular aura aboutGoldeye has a spectacular aura aboutGoldeye has a spectacular aura about
Send a message via AIM to Goldeye
If you run those pwms on interrupts, does anything go wrong?
How about high priority interrupts? Can the function run fast enough?
Team 694
2005 Championship - Galileo Semifinalist
2005 New York - Regional Chairmans Award
2005 New York - Semifinalist (Thanks 1257,1340)
"Automatic Transmission" Madison Technical Discussion 70 24-11-2003 09:03
The use of motors and parts in Dean's wheelchair archiver 1999 4 23-06-2002 23:12
The scoop on the Jideco motors... Joe Johnson Motors 3 30-01-2002 10:00
