Go to Post It's just another design constraint that needs to be dealt with. - Dave Scheck [more]
Unread 04-02-2006, 18:58
Goldeye Goldeye is offline
AKA: Josh Hecht
FRC #0694 (Stuypulse)
Goldeye has a spectacular aura aboutGoldeye has a spectacular aura aboutGoldeye has a spectacular aura about
Send a message via AIM to Goldeye
Re: I want a version of the mplab compiler for Linux.
Bump.
Originally Posted by psquared89
Sorry about the delay guys. I'm at Siemens (our build site) with the beloved John Dong right now, we've updated the configure.py script for the '06 stuff.
Put http://adambots.gotdns.com/adambots-...o/configure.py in your project folder, then run it with "python configure.py" to generate Makefiles. Re-run it every time you add/remove c/h files from the project.
Where can I find this now?
Team 694
2005 Championship - Galileo Semifinalist
2005 New York - Regional Chairmans Award
2005 New York - Semifinalist (Thanks 1257,1340)
Unread 04-02-2006, 20:26
AKA: Josh Hecht
Originally Posted by jdong
Ok, Three things:
(1) you should link mcc18-traditional to mcc18-traditional.exe using the command ln -sf /opt/mcc18/bin/mcc18-traditional.exe /opt/mcc18/bin/mcc18-traditional. This procedure must be repeated for cpp18 and _mplink.
(3) Get the MCC wrapper scripts:
http://adambots.gotdns.com/adambots-...s/mcc-wrapper/
An RPM is available for RPM users; else just copy the three scripts to /usr/local/bin, making sure that they are chmodded +x
Nevermind. I managed to fix it. Working configure.py attached. Do the above stuff (part 2 was excluded) to get it working. I made it compatible with both RCs, and also made it `make clean` when you run the configure. That can be disabled if you have a slow computer. Set CLEAN near the top to False.
Run ./configure.py old to make it build for the old rc.
Run ./configure.py alltimers to use FRC_alltimers.lib.
You can mix both for the expected effect.
I can't test upload till morning though.
Team 694
Unread 07-10-2006, 11:49
tux tux is offline
AKA: Lee Harr
FRC #3842 (Shock-a-Bots)
tux is an unknown quantity at this point
This link is dead:
But I found this one...
http://adambots.gotdns.com/adambots-...k/configure.py
Ahh.. never mind. I see now that you posted a link to the updated version.
Unread 07-10-2006, 14:13
tux tux is offline
AKA: Lee Harr
I was getting an error while linking ...
Error - could not find definition of symbol 'Serial_Char_Callback' in file './user_SerialDrv.o'.
But I figured out that the function had been deleted from user_routines_fast.c
It is compiling and linking just fine now.
Unread 10-10-2006, 00:46
Don Reid Don Reid is offline
Don Reid will become famous soon enough
Re: Wine version
We found that mcc18 doesn't work with recent versions of wine. One of the changes made between 0.9.18 and 0.9.19 seems to be the culprit. So you may want to stay with 0.9.18 or older.
Don Reid
Unread 26-10-2006, 18:09
114Klutz 114Klutz is offline
AKA: Li Pi
FRC #2984 (Viking Robotics)
114Klutz is a jewel in the rough114Klutz is a jewel in the rough114Klutz is a jewel in the rough
Send a message via AIM to 114Klutz
Does 0.9.23 work well? Or does that one also have similar problems?
Unread 27-10-2006, 13:47
I don't think we have tried it yet.
Don Reid
Unread 18-02-2007, 23:50
meatmanek meatmanek is offline
Programmer/physicist/mathematician
FRC #0868 (TechHounds)
meatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to behold
Things hosted on adambotslive are gone.
Unread 19-02-2007, 00:42
bagawk bagawk is offline
AKA: LeeP
FRC #0997 (Spartan Robotics)
bagawk is an unknown quantity at this point
We have a makefile that originally was made by that script and has been heavily modified. Grab it here: http://www.chsrobotics.com/files/Makefile
It should be fairly self-explanatory.
Unread 20-02-2007, 06:46
ScottWalls ScottWalls is offline
FRC #0245 (AdamBots)
ScottWalls will become famous soon enoughScottWalls will become famous soon enough
We have moved all of hour hosting. You can find everything (with Bazaar) at...
http://adambots.gotdns.com/bzr/mcc-wrapper/
Thank you all and keep on trucking.
Unread 20-02-2007, 14:29
I got configure.py and mcc-wrapper from adambots' bzr server. I copied mcc18 from our team's programming laptop, and put it into /opt/mcc18. I made symbolic links according to the suggestion earlier in this thread. I edited /opt/mcc18/h/p18cxxx.h. I ran configure.py, and when I run make, I get this error:
[code][Compiling ifi_utilities.o...
1. Checking Dependencies for ifi_utilities.o
2. Launching Compiler...
A thought to keep you occupied: /bin/sh: /usr/games/fortune: No such file or directory
Fortune not found.
Microchip MCC C18 Compiler
Version 0.0+SVN20050725
DEBUG:Using wine /opt/mcc18//bin/mcc18-traditional -p=18F8520 -fo ifi_utilities.o ifi_utilities.c /i"Z:\opt\mcc18\h" -D_FRC_BOARD -w3 pa=3 -O+ -nw=2066 -mL to launch MCC18
fixme:msvcrt:_spawnve only trying .exe when no extension given
Z:\home\meatmanek\techhounds\svn\test\ifi_utilitie s.c:0:Error: syntax error
Traceback (most recent call last):
File "/usr/local/bin/mcc18", line 49, in ?
raise Exception,"Compile FAILED"
Exception: Compile FAILED
make: *** [ifi_utilities.o] Error 1
/CODE]
Unread 20-02-2007, 15:37
Figured out my previous problem. Wine 0.9.22 has problems, so I updated to 0.9.29. Now I get a new error:
Fortune not found.
Z:\home\meatmanek\techhounds\svn\test\ifi_utilities.c:104:Message [3002] comparison of a signed integer to an unsigned integer detected
Z:\home\meatmanek\techhounds\svn\test\ifi_utilities.c:128:Message [3002] comparison of a signed integer to an unsigned integer detected
Z:\home\meatmanek\techhounds\svn\test\ifi_utilities.c:206:Error [1105] symbol 'ADC_0_TAD' has not been defined
Z:\home\meatmanek\techhounds\svn\test\ifi_utilities.c:207:Error [1204] too many arguments in function call
Lines 206 and 207 are:
OpenADC( ADC_FOSC_RC & ADC_RIGHT_JUST & ADC_0_TAD,
ADC_channel & ADC_INT_OFF & ADC_VREFPLUS_VDD & ADC_VREFMINUS_VSS,15);
Last edited by meatmanek : 20-02-2007 at 15:40. Reason: Added lines that are erring.
Unread 20-02-2007, 16:02
jdejoannis jdejoannis is offline
FRC #1845
jdejoannis will become famous soon enoughjdejoannis will become famous soon enough
Even by workaround standards, wine is a bad solution.
What are possibilities for a native linux port of only the C18 compiler? Perhaps there are volunteers who are willing to help.
Unread 21-02-2007, 00:19
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
That wouldn't be a port. That would be a whole new compiler.
Why? We have no source.
Unless someone wants to convince Microchip that there is a legitimate market for a linux compiler.
Unread 21-02-2007, 11:08
If we're lucky, SDCC will get support for pic18 soon.
I don't see anything wrong with using wine, though. This is exactly what it's meant for - running windows programs on linux.
MPLAB C18 problem Justyn Programming 0 09-03-2005 11:37
IMPORTANT regarding the new C Compiler dlavery General Forum 12 14-01-2005 05:05
Makefile and stripped down compiler Venkatesh Programming 0 09-01-2005 18:55
MPLAB IDE 6.60 Error mchan1111 Programming 8 08-11-2004 20:17
using the MPLAB IDE MPLAB SIM simulator WizardOfAz Programming 1 03-11-2003 01:24
