Go to Post No, nothing secret unless you include the following: will it work?, can it be driven and will it release the balls. - twolf [more]
Unread 04-02-2006, 19:16
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Omni wheels a partial no on ramp
Okay for those that said No, you are partially correct. I think we can live with our design. Video of the robot will hopefully be posted this weekend on our team's discussion board.
The robot drove good the first time with the code. When they added in code and control for zero degree spin, that worked the first time as well
We can get up the ramp if a second robot is behind us keeping the robot from spinning and rolling down the ramp when the front wheels are about 3/4 the way up the ramp. I know this because I was able to put my feet on the back end while seated behind the robot which keep the angle of attach perpendicular to the ramp. Once the front tires get over the lip they are back on a level surface and pull the robot over the top. It is a lot of spinning wheels So one of those alliance partner robots with the IFI or AM traction tires gets behind us we are up and on without too much work.
On the plus side, it is way to cool to swerve or strafe
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
pic: 350 drive train CD47-Bot Robot Showcase 4 16-02-2004 00:05
pic: Team 870 Front Drive Train CD47-Bot Robot Showcase 4 27-02-2003 15:23
pic: Team 870 Rear Drive Train CD47-Bot Robot Showcase 2 27-02-2003 00:22
pic: Team 980 "Thunder Bot" drive train CD47-Bot Robot Showcase 12 25-02-2003 14:02
pic: 311's Drive Train CD47-Bot Robot Showcase 2 24-02-2003 18:09
