Go to Post We have tried doing the cha-cha slide on the airplane, but that went away very quickly - it seems that the pilots don't like all the movement in the plane. - Carol [more]
Unread 04-02-2006, 18:47
MacFlightSierra MacFlightSierra is offline
FRC #0912 (Iron Lyons)
MacFlightSierra is an unknown quantity at this point
Using 7.2v charger as BackupBattery
We have been experimenting with the camera for some time now, and among other problems, we noticed that the little 7.2v backup battery runs out very fast. We can only get 3-4 mins of operational time out of it, before the BackupBatt LED on the OI turns red and the camera stops working.
My idea was to use the IFI supplied charger for that battery, instead of the battery itself (hook up the charger output to the BackupBatt RC Input). I measured the charger outputs- 8.0v @ 750mA -just like the backup battery itself.
My question - is that idea safe (for experimental use of course)? Any chance it might screw up the camera or the RC itself?
any feedback would be greatly appreciated
thanks
Unread 04-02-2006, 19:09
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Re: Using 7.2v charger as BackupBattery
thanks
I was able to apply 12v to the backup battery input with no ill effects.
I used that setup for quite a while before we had the robot together...
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 04-02-2006, 19:51
Jared Russell's Avatar
Taking a year (mostly) off
And I've been running it at 5V without problems as well. Seems those little cameras have pretty good voltage regulating capabilities
Unread 04-02-2006, 23:00
Mac,
It is never a good idea to use a battery charger as a power supply. Frequently chargers use a pulsed DC output that is well above what you might be measuring. If your backup battery runs down in 3-4 minutes there is something wrong. Either the charger isn't fully charging the battery, or it has a defective cell or there is a short in the wiring to camera or the camera has a defect and is drawing too much current. You need to find the reason and correct it.
Unread 04-02-2006, 23:02
ForgottenSalad's Avatar
ForgottenSalad ForgottenSalad is offline
In search of a home...
AKA: Michael Wessler
ForgottenSalad will become famous soon enoughForgottenSalad will become famous soon enough
Send a message via AIM to ForgottenSalad
As far as the backup battery dying in 3-4 minutes, we had the same problem until we realized why it was happening, and it was beacuse we were powering the servos off of the camera board instead of off the rc. Is that possibly what you're doing?
Unread 04-02-2006, 23:03
The CMUCAM2 spec sheet says it will run on 6 to 15VDC. Why not use the 12V main power on the 'bot? The camera is not much drain on the big battery, and then the backup battery can go back to its life of neglect and apathy.
Even if it didn't like 12VDC, I'd be tempted to get a voltage regulator and run it off the 12VDC main battery anyway.
Unread 05-02-2006, 14:49
Rick,
The IFI website lists the camera power as "7.2 VDC nominal @ 235mA. 5.2V - 8.6V range max, up to 20 V if internal servo jumper removed." A blanket statement that the camera can run on 12 volts is not entirely true. If you are depending on your camera to help in competition, know that it will fail if the power falls below the range stated. Robot main power for many teams will regularly drop below 5 volts during high current demands and the 7.2 volt backup supply is not tied to the main power. Want to keep the camera operating, use the recommended connections to the backup battery.
Unread 05-02-2006, 17:16
thank you all for your advice
[never actually connected the charger as I thought]
We disconnected everything from the controlller [all victors and spikes], and got 20 mins if playing time with the camera [and the backupBatt LED never came on].. I guess there were some problems with our initial setup - we'll be more careful next time we wire it
thanks again and good luck
Unread 05-02-2006, 17:22
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
20mins is still far too short. As a reference, ours will last for 2-3 hours before we have to change it (The RC doesn't register it as dead, but the camera has problems locking on). Something is defineitly up with either your camera or wiring.
Unread 05-02-2006, 18:27
Bharat Nain's Avatar
Do you have more servos or anything that will eat up your backup battery?
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 05-02-2006, 19:37
2 -3 hours? wow... we dont have any other servos connected, so nothing else is eating the battery's power. I will conduct a full test tomorrow and see what we get.
What could be wrong in this case [except for a faulty battery/camera]? It just a simple battery <-> controller connection.. weird.
Unread 05-02-2006, 20:01
Rookie Year: 1234
Short on the back of the camera? Take it off the pan/tilt mount and see what kind of battery life you get. Do you have another backup battery? If not you may want to get another for a couple reasons: You will discharge it during a competiton, and you will need one for the robot while the other charges. It will also assit you here, as you can rule out the battery being bad.
For now, you may want to see if anyone on your team has one, as the connector/battery is common in RC cars. Someone said in this thread, they gave the backup battery connector 12v, and it worked. You may want to try a 9v battery connected to it, but there's the chance of frying the RC (I take no responsibility)
Unread 05-02-2006, 20:53
Eldarion's Avatar
I don't think a 9v battery will work; the RC draws a lot of current from the backup battery terminals!
-- Thomas Paine
-- Anonymous
Unread 05-02-2006, 22:59
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
3-4 mins is too short a life for the backup battery, but it is long enough for competition. We plan on bringing 3 backup batteries and switching them between every match just like we do the 12v batteries, especially with how important it will be to not lose camera power mid-match.
Unread 10-02-2006, 00:45
bhsrobotics1671's Avatar
bhsrobotics1671 bhsrobotics1671 is offline
Andrew Nabors
AKA: Andrew Nabors
FRC #1671 (Buchanan Bird Brains)
bhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to behold
thanks
we did that on our team, and found out the camera didnt work properly, we couldnt do anything in labview, it kept shorting out i guess you could say. at first we didnt know what the problem was, so we called the guy who invented the camera because we thought they sent us a defective one, but it was just that we needed to use the battery, and couldnt use the charger
Buchanan Bird Brains - FRC Team 1671
2015 FIRST World Champions
118, 1678, 1671, 5012
Problem with the battery charger Lightposter Electrical 4 19-01-2006 10:39
OH NO! I left the charger ON!!! sanddrag Electrical 11 11-03-2005 19:57
Battery charger model# ? computhief263 Programming 3 22-03-2004 13:21
Multiple Batteries from one charger Venkatesh Electrical 16 03-03-2003 23:39
6 Volt charger...? kangarue23 Technical Discussion 7 12-04-2002 10:35
