Go to Post A big bowl of popcorn and FIRST. It doesn't get much better than that. - Warren Boudreau [more]
Unread 04-02-2006, 17:29
Kyveck Kyveck is offline
FRC #1014 (Dublin Robotics)
Kyveck is an unknown quantity at this point
ADC code effecting motor outs???
Our robot's motors seem to be receiving some sort of signal even when all pwm outs are hardcoded to zero. We systematically turned off sensors and bits of code, until we isolated the problem with the adc software. Unless we disable the adc code, (by commenting out the adc initialization or the adc/timer interrupt routines) the drive wheels act as if they are set to 10 or 20 above neutral, instead of 127. If we enable the joystick and pull it back about 10 or so, the wheels stop. If we set one wheel to be mapped as (255-p2_y) then ten forward or so stops one wheel and speeds up the other, and vice versa. If we change the sampling rate from 200Hz that we were using to 800Hz, then the wheels spin much faster, but in the same manner.
If anyone has any clue what's going on, I would be very grateful for insight. I realize that both ways that we have found to stop the motor movement have the net effect of not causing any adc interrupts, but I don't see what could be going wrong. The dashboard viewer continues to read neutral pwm values for all RC pwm outs. The gyro is on analog in 1, and the motors are on pwms 13 and 15. We have patched in Kevin Watson's gyro and adc code, version 0.4. Once again, if any one can help, we'd all appreciate it.
KLW,
Controls Software Lead,
Team 1014, Dublin Robotics (Bad Robots)
Unread 04-02-2006, 18:25
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Re: ADC code effecting motor outs???
This explains the symptoms we've been seeing as well. Our current code (which uses Kevin's ADC code for the gyro, DAA, and one other channel) shows a slightly positive value on the PWMs, but the default code doesn't. It 's not causing us any problems, but it's enough to cause the CIMs to hum even when everything is set to 127.
Unread 04-02-2006, 19:37
Jared Russell's Avatar
Taking a year (mostly) off
This is news to me...
Have you tried recalibrating the speed controllers?
Unread 04-02-2006, 19:41
This is more than a slight hum. At 800Hz, the robot drives about 3 m/s when we take it off blocks.
Unread 04-02-2006, 19:56
Kevin Watson's Avatar
La Cañada High School
FRC #2429
KLW,
The problem is that PWM channels 13-16 are "bit banged" by code running on the user processor. When you have a lot of interrupts firing-off in the background, IFI's code get's interrupted while running, which causes jitter in the outputs. The only solution is to not use PWMs 13-16.
-Kevin
Kevin Watson
http://kevin.org
Unread 04-02-2006, 20:47
Thanks. That makes sence. I tried to find the source for the Generate_pwms function, but it was in a library. Between the adc, timer, serail comms, and encoders, we probably get about 400 interrupts a second. We'll just switch to a different pwm out. Thanks again,
KLW
Unread 04-02-2006, 23:06
kaszeta's Avatar
Ours are calibrated. For us, the problem is slight (it's just a few steps outside of the Victor's deadband).
Unread 04-02-2006, 23:07
kaszeta's Avatar
That's rather what I suspected. I'll try having the guys shuffle around the PWMs.
Unread 05-02-2006, 21:31
Mike Bortfeldt Mike Bortfeldt is offline
FRC #1126 (& 1511)
Mike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud of
Kyveck,
If you still want to use PWMs 13-16, you can try this piece of code (hopefully this is the working version...). It replaces the Generate_Pwms function call and utilizes Timer 3 and the CCP modules to control the pwm 13-16 pulse width. Since the pulse is controlled by hardware, it should be independent of other interrupts. My team was planning on using PWM 13, 15 & 16 this year in order to improve the Victor response time since PWMs 1-12 seem to put around a 50 millisecond delay between setting the pwm output variable and for the Victor to respond (communication to the master processor plus some other delay). But based on the recent comments I've read on CD, having a jittery PWM output would not be unacceptable.
I have not had a chance to do any extensive testing on this code other than a quick check to be sure that it is indeed generating a 1-2 millisecond pulse, so it may still have some bugs. I plan on running more tests over the next week but if you decide to use it and have any questions or problems, let me know.
Mike
Unread 05-02-2006, 21:47
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Thanks for posting that code. I will be trying it out sometime soon, but I will have to port it to Timer 2, as Timer 3 is in use already.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 06-02-2006, 01:42
FRC #2429
Originally Posted by Mike Bortfeldt
Kyveck,
Mike
Mike, this is cool. If someone has some free time <grin>, a good experiment would be to use Mike's code to see if you can wring-out a little more pointing accuracy from the camera servos.
-Kevin
Kevin Watson
http://kevin.org
Unread 06-02-2006, 09:25
kaszeta's Avatar
I'm working on that as a side project.
Unread 06-02-2006, 09:38
Joel J's Avatar
Joel J Joel J is offline
do you..
This made me smile:
pwm13 * 40; // Calculate the time delay for PWM13
CCPR2 = PROD + 9913;
Beautiful!
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 27-03-2006, 20:07
Gary Bonner Gary Bonner is offline
FRC #3974
Gary Bonner has a spectacular aura aboutGary Bonner has a spectacular aura about
Can someone explain what this does, particularly the first line?
Thanks.
Unread 27-03-2006, 20:14
Joel J's Avatar
do you..
The first line does a multiplication. When you do a multiplication on the PIC, it is stored in the PROD register. The second line gets the value from the PROD and uses it. He does it this way so he has one less section to save before servicing the interrupt.
Joel Johnson
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Analog-to-Digital Converter Code Kevin Watson Programming 29 17-02-2008 13:07
adc code problem railerobotics Programming 6 24-01-2006 22:26
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
