Go to Post Yay for teaching how to fish! - RoboMom [more]
Unread 02-02-2006, 08:18
Ebolagirl's Avatar
Ebolagirl Ebolagirl is offline
I <3 Inventor!!!
AKA: Tracey
FRC #0418 (Purple Haze/LASA Robotics)
Ebolagirl has a spectacular aura aboutEbolagirl has a spectacular aura aboutEbolagirl has a spectacular aura about
Send a message via AIM to Ebolagirl
Torus!!!
Hello,
Does anyone know how to make a torus in Inventor 10? I've tried many methods already and I still haven't figured it out. I have even checked the "help" thing in Inventor and have searched online. Any help would be great.
Thank You,
Ebolagirl
"Show a girl how to use a wrench, and she'll put those skills to use for a lifetime. Hand it to her and tell her she's probably better off shopping, and she'll clonk you over the head with it, do your pneumatics system, and CAD the robot."
-Someone
My other passion... http://www.cdc.gov/ncidod/dvrd/spb/m...s/ebola/qa.htm
Isn't it adorable?
http://www.giantmicrobes.com/calamities/ebola.html
Unread 02-02-2006, 09:25
Re: Torus!!!
Although there should be a 3D object included, you can always back into a torus by constructing a round object of the correct diameter and thickness, inserting a hole through the object and then filleting all edges to the radius of half the thickness of the object.
Unread 02-02-2006, 09:30
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Torus!!!
Draw a circle. On a perpendicular plane, draw another circle such that the center of it lies on the first circle. Sweep the profile of the second circle around the path of the first circle. You could also do it in one sketch by Revolving a circle about a line.
Unread 03-02-2006, 20:43
Ebolagirl's Avatar
I <3 Inventor!!!
AKA: Tracey
Re: Torus!!!
Thanks y'all!! I figured it out how to do it. I've also officially decided that torus shaped things are my favorite shapes in Inventor (especially when the material is black chrome).
-Someone
Isn't it adorable?
Unread 04-02-2006, 00:22
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Re: Torus!!!
another easy way to do it is make a new sketch, make a circle and then off to the left or right, make a verticle line. then finish the sketch, revolve, select the circle as your area and the line as your axis.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 04-02-2006, 17:47
Ebolagirl's Avatar
I <3 Inventor!!!
AKA: Tracey
Re: Torus!!!
That was one of the first things I tried actually, and it didn't work out so well. I also tried doing a circular pattern, which didn't work well either.
-Someone
Isn't it adorable?
Unread 04-02-2006, 20:57
AndyB's Avatar
AKA: Andy Burchardt
Re: Torus!!!
interesting, are you sure your line was straight verticle and that you revolved it fully?
Unread 05-02-2006, 12:52
Ebolagirl's Avatar
I <3 Inventor!!!
AKA: Tracey
Re: Torus!!!
Yup, and it just freaked out. Sometimes Inventor is quirky though.
-Someone
Isn't it adorable?
Unread 22-04-2006, 10:04
negfrequency's Avatar
negfrequency negfrequency is offline
the guy with the drawings
AKA: Willomatic
FRC #1559 (Devil Tech)
negfrequency is just really nicenegfrequency is just really nicenegfrequency is just really nicenegfrequency is just really nicenegfrequency is just really nice
Send a message via AIM to negfrequency
Re: Torus!!!
ummm. You could apply the vertical constraint just to make sure before you revolve it. I just made it, and revolving the circle means that you can do it quicker by not having to establish the second work plane and sketch.
www.evolved-ideas.net
-KOP CAD parts available for download
You know your me if.....
5) your 91 honda civic dx drives @ warp .000005376, not 60 mph
4) You know what "Bi-directional parametric associativity" is
3) Playing Diabolo does NOT mean you are a level 24 mage.
2) You've discovered you can rearrange the letters in William to spell "I am Will".
1) Your bicycle is 3 times more expensive than your car.
