Go to Post Think about the other teams...today your opponent, today your teammate. - Al Skierkiewicz [more]
Unread 04-02-2006, 20:35
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Robot Runs in full Reverse
I am using the camera code from kevin's website and have modified it alot, i have been using the Arcade 1-Joystick drive that is commented out in the defult
code. My problem started when i tried to switch two a Two Joystick drive system. My problem is the robot runs in full reverse. So i made my Program print the values from p1_y, p2_y, pwm03, and pwm04(the drive pwms). But what confuses me is the p1_y and p2_y print as 127 when the joystick is centered but pwm01 and pwm02 = 0. if i move the joystick the pwm values do not change. My code is below:
pwm03 = Limit_Max(p1_y);
pwm04 = Limit_Max(p2_y);
my 1 joystick code is below:
pwm03 = Limit_Max(p1_x + p1_y - 127);
pwm04 = Limit_Max(p1_x - p1_y + 127);
Can anybody help?
Unread 04-02-2006, 20:38
Jared Russell's Avatar
Taking a year (mostly) off
Re: Robot Runs in full Reverse
Easiest solution - don't use Limit_Max.
Your joystick will never give values outside the acceptable range. Whatever Limit_Max is supposed to do, it isn't.
Unread 04-02-2006, 21:01
AKA: Eric Haskins
I would like to understand why Limit_Max would not work the way it is suppose to. And why it would be in the default code when it isn't needed?
Unread 04-02-2006, 21:14
Are you sure you don't mean Limit_Mix? The default code doesn't have a Limit_Max that I can see.
Limit_Mix requires that you add 2000 to the value you pass to it. It's a silly trick to try to avoid an even sillier behavior by the compiler, but it works.
Unread 04-02-2006, 21:19
Andrew Blair's Avatar
FRC #0306 (CRT)
Limit_Max and Limit_Min are function to control limit switches. They control motor outputs that should be limited by a limit switch. Alan is right; Limit mix is the actual function that you want to use. That should give you the reaction that you expect.
Edit--------------------------------------------------------------------
This is for 1 joystick drive. For two, as Alan says below, just assign them directly.
-Sir Francis Bacon
-Albert Einstein
Unread 04-02-2006, 21:33
Actually, for two-joystick control, LimitMix isn't appropriate either. Its only purpose is to mix the x and y axes of a joystick for single-joystick control. It subtracts 2000 from its input as part of doing its job.
Abwehr is right -- just copy the joystick values to the pwms.
  pwm03 = p1_y;
  pwm04 = p2_y;
It's that simple.
Unread 04-02-2006, 23:39
AKA: Eric Haskins
Thanks everyone this has all helped alot!
[moderated]: A Challenge: YOU Rewrite G25 Tom Bottiglieri General Forum 10 30-03-2005 21:18
How much do you design before kickoff? Allison K General Forum 19 07-12-2004 21:32
what kind of robot will win? Bcahn836 Championship Event 44 12-04-2004 00:02
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
