Go to Post I personally think that everybody on the team is important. No matter what, every single student, mentor, teacher put their effort all year long to get the team going. So in my opinion, Credit goes to everyone. - Arefin Bari [more]
Unread 04-02-2006, 18:34
Motors and the High Port Numbers
Has anyone ever had joy using PWM13-PWM16 for motor controllers?
Unread 04-02-2006, 18:39
Gdeaver Gdeaver is offline
FRC #1640
Re: Motors and the High Port Numbers
I believe these are slow refreshed PWM outputs. Also they can glitch if there are conflicts with the interrupts.
Unread 04-02-2006, 18:42
lemoneasy lemoneasy is offline
AKA: Evan Crawford
FRC #1334
lemoneasy is on a distinguished road
We are currently using them as our motor controls, we are having a problem right now if we start the bot with camera off it turns in circles . While it tracks it kind of twitches, is that what you mean by the glitch if it conflicts with the interrupts Gdeaver? If so, you just made my day, couldn't find the twitch anywhere in the camera or tracking code.
Unread 04-02-2006, 18:45
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Actually, they are the fast (7ms update possible, vs. 26.6ms update) PWM outputs, but they require a call to
Generate_PWMs(pwm13, pwm14, pwm15, pwm16); every time you want them updated.
They can glitch with interrupts, but I have never seen this happen personally.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 04-02-2006, 18:50
AKA: Evan Crawford
FRC #1334
I will try commenting out sections of the interupt code on monday, to see if I can locate the glitch, I'm also wondering if theres any chance of a conflict between cmuCam2's TTL input interfering with high port numbers for motors? We are generating the pwms each run through the code as you have written above, and it seems are problem with a slight twich is associated with the camera tracking or initializing, but I have yet to pinpoint what in it, and it seems no one else has had this problem yet...
Unread 04-02-2006, 18:52
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
I have seen a similar issue with the servos on the camera. I had them connected to PWM 1 and 2, and when I accidentally discharged static to the chassis of the robot, or connected the serial cable to the program port, the servos would twitch, big time. This doesn't prove to be an issue with the tracking code, though. I have never connected anything to 13-16, though. I use 16 to power the camera. That's probably all it's good for...
I remember reading somewhere that the new master code cures a twitch, but I don't know if it's the 13-16 issue, and I haven't upgraded, so I don't know.
Good luck,
JBotAlan
Aren't signatures a bit outdated?
Unread 04-02-2006, 18:53
Our lead programmer wrote his own PID code. In testing, nothing worked right using the high PWM ports. He used Generate_Pwms, too. When we moved the control to PWM 3 & 4, it started working. No worries, it only cost us a day...
Unread 04-02-2006, 19:20
FRC #1640
Check me but the lower PWM ports are controlled by the master proc. the high ones are software generated by the user proc. Interrupts are almost guaranteed to affect the upper PWM ports.
Unread 04-02-2006, 19:38
Jared Russell's Avatar
Taking a year (mostly) off
We've had some wacky stuff happen on ports 13-16. I would recommend forgoing them altogether.
Unread 04-02-2006, 19:41
So, if we are using encoders, which use interrupts, to control speed on the four high PWM ports, which are interrupt-sensitive, we aren't just shooting ourselves in the foot, but actually firing an M16 on full auto directly into our arch, right?
Unread 04-02-2006, 19:59
Kevin Watson's Avatar
La Cañada High School
FRC #2429
This is documented in the CMUcam2 FAQ: http://kevin.org/frc/camera.
-Kevin
Kevin Watson
http://kevin.org
Unread 04-02-2006, 21:22
Just say no to PWMS 13-16.
Never used them, never will.
They seemed like a good idea at the time...
Unread 04-02-2006, 21:38
We've been using pwm16...
...for camera power.
Unread 04-02-2006, 21:39
Guilty
Unread 04-02-2006, 21:43
I've been reading that the camera is intended to run off the backup battery. Do the PWM ports provide the right voltage for the, you know, camera?
"Automatic Transmission" Madison Technical Discussion 70 24-11-2003 09:03
The use of motors and parts in Dean's wheelchair archiver 1999 4 23-06-2002 23:12
The scoop on the Jideco motors... Joe Johnson Motors 3 30-01-2002 10:00
