Go to Post You won't find anything in school that says you have to share ideas or strategy with your football rivals. - Al Skierkiewicz [more]
Unread 04-02-2006, 21:58
Re: Motors and the High Port Numbers
The servo power on the pwm output pins comes from the backup battery.
Goldeye Goldeye is offline
AKA: Josh Hecht
FRC #0694 (Stuypulse)
Goldeye has a spectacular aura aboutGoldeye has a spectacular aura aboutGoldeye has a spectacular aura about
Send a message via AIM to Goldeye
If you run those pwms on interrupts, does anything go wrong?
How about high priority interrupts? Can the function run fast enough?
Team 694
2005 Championship - Galileo Semifinalist
2005 New York - Regional Chairmans Award
2005 New York - Semifinalist (Thanks 1257,1340)
Unread 04-02-2006, 22:29
6600gt's Avatar
6600gt 6600gt is offline
AKA: Lohit
FRC #0226 (Hammerhead)
6600gt is a jewel in the rough6600gt is a jewel in the rough6600gt is a jewel in the rough
Originally Posted by Eldarion
Actually, they are the fast (7ms update possible, vs. 26.6ms update) PWM outputs, but they require a call to
Generate_PWMs(pwm13, pwm14, pwm15, pwm16); every time you want them updated.
They can glitch with interrupts, but I have never seen this happen personally.
Actually the Pwm's 1-12 are 17ms speed normal refresh rate while the Pwm's 13-16 have a 2 ms refresh rate. Victors can work with the fast 2ms refresh rate, servos can't.
I think the Pwm's 13-16 are hardware generated from pins called CCP1, CCP2,...
I don't understand how these can be affected by the software?
The values are in software but if the software is slow to execute then the value just won't change really fast.
Unread 05-02-2006, 09:27
For these pwms 13-16 alone, the software gets direct control to generate a timed pulse of between 1 and 2 ms duration, 1.5ms being neutral.
Any interrupts, interrupt the software timing these pulse widths, but the software doing the timing doesn't know this. Just like none of your other regular code is ever aware an interrupt has occurred. So the software happily generates what it thinks is a neutral pulse of 1.5ms, but any interrupt handler that pops in, suspends the execution of your code, does it's thing, and returns control will extend or stretch the time of your pwm pulse by the amount of time it took to service that interrupt.
So instead of a 1.5ms pulse, for example, you'll end up with a 1.8ms pulse.
And your robot drives away.
"Automatic Transmission" Madison Technical Discussion 70 24-11-2003 09:03
The use of motors and parts in Dean's wheelchair archiver 1999 4 23-06-2002 23:12
The scoop on the Jideco motors... Joe Johnson Motors 3 30-01-2002 10:00
