Go to Post I have gone and confused myself again. Why does this happen every time? - Jay Trzaskos [more]
Unread 05-02-2006, 12:02
6600gt's Avatar
6600gt 6600gt is offline
AKA: Lohit
FRC #0226 (Hammerhead)
6600gt is a jewel in the rough6600gt is a jewel in the rough6600gt is a jewel in the rough
Re: Stupidest Programming Mistakes
if(joyin - pwmout > rate)
pwmout = pwmout + rate;
joyin - pwmout could be negative but they were all unsigned variables so it never looked at nagatives. So for example it would still execute when (-10 > 5)
Took 2 hours to realize that!
Unread 05-02-2006, 12:42
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
I won't mention the hundreds times I've forgotten a semicolon, I'm sure that's all too common.
So I'll mention the time I was debugging a version of code and wondering why the printf's weren't working. Turns out I was downloading the old (buggy) version of the code
http://www.mikesorrenti.com/
Unread 05-02-2006, 13:21
theycallhimtom theycallhimtom is offline
AKA: Tom Conerly
FRC #1540 (The Flaming Chickens)
theycallhimtom has a spectacular aura abouttheycallhimtom has a spectacular aura abouttheycallhimtom has a spectacular aura about
Send a message via AIM to theycallhimtom Send a message via MSN to theycallhimtom
Working on code for a few days working through all the bugs. Then when it coms time to use it a few weeks later I have lost the code and have forgotten how I fixed all the problems I came across. So I had to redo the code and attempt to remeber how I dealt with each error.
Also assuming that ints were 32 bit caused me some pain.
Oh and almost every day when I download code to the robot I download from the wrong project and realize it a few mins later when the printfs are all wrong.
Unread 05-02-2006, 14:04
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
One of the things that keeps tripping us up is that the MPLAB compiler does not follow standard C data type promotion rules.
For example, given the statement below, standard C would promote both data types to integer, then multiply. The MPLAB compiler, however, multiplies a and b as unsigned chars and then sticks the result in the integer value, resulting in an overflow where you least expect it!
unsigned char a = 127:
unsigned char b = 127;
int result;
result = (a * b);
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 05-02-2006, 15:19
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
We've had QUITE a few:
to convert angle radians to degrees:
int tiltdeg = tiltrad*( (int)3.14 / 180 );
hmmm, no wonder why we kept getting "0" as a tile angle...
and oh yeah, it shoulda been 180/3.14 to begin with...
In trying to comment stuff out with "/* */", we realize that we comment out other stuff already commented out using the same method, and whenever it reached that comment's "*/" it would end, causing a bunch of syntax errors throughout the rest of the uncommented code, and we couldnt figure out for the life of us why it was reading that code...
and dont know what we were thinking here:
if(TILT_SERVO > Tilt_Servo_Max)
TILT_SERVO = Tilt_Servo_Max - Tilt_Servo_Min + Step_Size;
um, I think we were trying to have the camera search in the last area it saw the light if it immediately loses it too high...but um.. Tilt_Servo_Min = 0 and Step_Size is greater than 0...
Unread 05-02-2006, 15:24
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Little trick Mark McLeod showed me for that:
#ifdef //This is actually a comment block, #1
code
code
code
#endif //This is the end of comment block #1
Since the #ifdef is missing something to check, it always fails, so any code in it never compiles, doesn't get stopped by */, quite useful
Matt Krass
Unread 05-02-2006, 17:03
Mike Shaul's Avatar
Mike Shaul Mike Shaul is offline
FRC #0065 (Huskie Brigade)
Mike Shaul has a brilliant futureMike Shaul has a brilliant futureMike Shaul has a brilliant futureMike Shaul has a brilliant futureMike Shaul has a brilliant futureMike Shaul has a brilliant futureMike Shaul has a brilliant futureMike Shaul has a brilliant futureMike Shaul has a brilliant futureMike Shaul has a brilliant futureMike Shaul has a brilliant future
The C Programing language has MANY different "issues" with undefined behavior or easy-to-make mistakes that compilers won't usually catch.
This website has compiled 10 (actually more than 10) common mistakes, check it out.
By far the best proof is experience. - Sir Francis Bacon
Unread 05-02-2006, 18:12
Goldeye Goldeye is offline
AKA: Josh Hecht
FRC #0694 (Stuypulse)
Goldeye has a spectacular aura aboutGoldeye has a spectacular aura aboutGoldeye has a spectacular aura about
Send a message via AIM to Goldeye
My teammate made a great slipup that him and a mentor didn't catch till I looked. Here it is (with the error) in a function for averaging something in pseudocode.
int sum,count;
while(stuff_left)
     sum+=stuff;
     count++;
if(!count == 0)
     return -1
else
     return sum/count;
Team 694
2005 Championship - Galileo Semifinalist
2005 New York - Regional Chairmans Award
2005 New York - Semifinalist (Thanks 1257,1340)
Unread 05-02-2006, 18:50
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
I havent made any hilariously dumb mistakes coding, i have done the condition after the else statement but i caught it quickly and i have also done the good old no semi-colon, but my most hilarious story is from an alumni from our team on his first programming attempt,
Basically to init his PWM values he set them to 0 logically thinking that zero meant no speed, the robot the ran full speed backward over the laptop he was using to program giving it the name "smokey" for ever and now i have to try and fix this old i286 laptop to use for some random off season stuff
KK4KQO
http://voltair.us
Unread 05-02-2006, 19:11
Kristian Calhoun's Avatar
Kristian Calhoun Kristian Calhoun is offline
Celebrating 20 years of 25
FRC #0025 (Raider Robotix)
Kristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond repute
Send a message via AIM to Kristian Calhoun
this was one that someone els eon our programming team made that i had caught. we kept trying to compile the code and we kept getting an error, it ended up that instead of pwm01 and pwm02, that the other member of our team had put pwn01 and pwn02. we reached the conclusion that you cannot pwn the pwms lol.
Raider Robotix: Home | Twitter | Facebook | Instagram
Brunswick Eruption: Home | Twitter | Facebook
Unread 05-02-2006, 20:47
scitobor 617's Avatar
scitobor 617 scitobor 617 is offline
More nerd than you can handle!
AKA: Alan Meekins
FRC #0617 (HSHS 617 "DUKE")
scitobor 617 will become famous soon enoughscitobor 617 will become famous soon enough
Send a message via AIM to scitobor 617
For some reason whenever I open a project in MPlab it automaticlly opens user_routines.c from an old version of my code. It took me half of a saturday to figure out way changing stuff in user_routines.c had no effect what so ever, even when I intentionally added errors that should have caused all kinds of compile time errors. I still do not know what is causing this but I now know to check which file I'm editting before I make any changes.
Beta testers needed!
http://www.nullagent.no-ip.com
Your kidding, there are other operating systems besides Linux?!
Unread 05-02-2006, 23:46
BrianR BrianR is offline
AKA: Brian Roehl
FRC #1525 (Warbots)
Team Role: Electrical
BrianR has a spectacular aura aboutBrianR has a spectacular aura about
Send a message via AIM to BrianR
Today we were trying to do our angle calculations, and we had made a trig mistake. So we changed it and uploaded the code. But for some reason it kept having the same problem. After we changed some other stuff to no result, we happened to notice that the loader was calling the wrong code, and that for some reason, it had built the .hex file to a different spot. Once we figured that out, it worked like a charm.
Unread 09-02-2006, 00:33
jfelser jfelser is offline
FRC #0948
jfelser will become famous soon enough
Send a message via AIM to jfelser
I dunno if this is truly a programming mistake... but testing autonomous (using PID) we forgot to plug in one of the the interrupt pins on the encoders, resulting in a very interesting open-loop control system, and various material damages (the robot LED, the green light, the 6' stack of books the light was sitting on, the desk the books were sitting on, the counter with microscopes behind the desk with the books and light, and my self confidence).
Code Red Robotics Team 639 | www.team639.org
2004 Canadian SUPER Regional Winners with 33 & 1112, GM Industrial Design Award
2005 Finger Lakes Regional Winners with 191 & 494, Canadian Regional GM Industrial Design Award
Newport Robotics Group Team 948 | www.nrg948.org
2006 Portland Regional Motorola Quality Award Winners
2007 Portland Regional Finalists with 1540 & 1778, GM Industrial Design Award
-Jake Felser-
Unread 15-02-2006, 22:45
aaeamdar's Avatar
aaeamdar aaeamdar is offline
Post-A-Holic
AKA: Paul Dennis
FRC #1719 (The Umbrella Corp)
aaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant future
I had this:
auto_mode = ~auto_select1 + 2(~auto_select2) + 3(~auto_select3);
Where auto_mode is later used in a switch{case:}, and auto_selectNs are variouss rc_dig_ins.
Can someone spot the error there? Yeah, 2() is not a valid method. So I changed it to this:
auto_mode = ~auto_select1 + 2*(~auto_select2) + 3*(~auto_select3);
And it still didn't work. Gee whiz. What is wrong now. It gives me a run-time unexpectedness glitch where auto_mode is calculated to be 246 or some nonsense like that. OK, fixed that by not using the binary complement and instead used the logical complement (in a #define) and it works.
In another one we had:
printf("Some motor values %d %d %d", 1,2,3);//Whatever
And nothing was printing. Gosh, that sure was weird. Well, it turns out that we failed to import stdio.h (or anything else that gives us access to printfs). And then, to make things worse, the C language is so incredibly stupid that all it gives you is a warning because it's not prototyped. Since we had been using some other methods that weren't prototyped (may have been a few in Kevins Code) those warnings got mushed in with the others.
Thank goodness for Java.
Paul Dennis
Unread 15-02-2006, 23:19
Jake M Jake M is offline
void* Jake;
FRC #1178 (DURT)
Jake M has a spectacular aura aboutJake M has a spectacular aura about
How about spending an hour trying to decipher a run-time error and systematically commenting all of our added code up to that point, only to later find we were compiling with the 2005 FRC settings instead of 2006?
Oh, and this isn't really a programming error, but I still think it's up there as stupid. In our third or fourth practice match last year, our robot suddenly started smoking out on the field. We had used a large ribbon cable to wire the camera and dozens of switches throughout the robot for use in autonomous mode to sense and pick up tetras, and cap them, which had been working perfectly. As it turns out, several of the spare wires, which was about half of the cable, that had been cut off from removed sensors and never removed from the electronics, and that included several five volts and grounds, had brushed up against the frame, which, simply put, melted the entire cable and fried our camera.
void function(void)
  function();
Programming Vex w/ MPLab dababyjebus FIRST Tech Challenge 27 25-04-2008 09:11
Programming - Getting Started Mark McLeod Programming 80 16-04-2008 23:37
VEX programming Gene F Programming 14 08-08-2006 22:21
Suggestion for Delphi Programming Posts Chris Hibner CD Forum Support 1 27-07-2005 10:02
Robot Programming Education phrontist Programming 11 03-05-2004 07:32
