Go to Post (OK, now that I have said this, just watch someone like Kevin Watson have a working solution by this Friday... :yikes: ) - dlavery [more]
Unread 05-02-2006, 12:27
Bcahn836's Avatar
Bcahn836 Bcahn836 is offline
Iraq is fun.
AKA: Brad Cahn
no team (Robobees 836)
Bcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond repute
Send a message via AIM to Bcahn836 Send a message via Yahoo to Bcahn836
Re: pic: Team 836 Teaser # 2
We hope to have a white paper done most likely after build season when we can find the time to make an accurate one.
Some general info:
2 speed
neutral
and a brake system
We are planning to use 2 Cim motors depending on weight, right now we are doing everything we can to lighten the whole thing like using these gears and hopefully we can take out even more weight on the bolt on by shaving down the front and back plates. By the time we get done the whole assembly with out the cims should weight somewhere between 5-8 Lbs.
Unread 05-02-2006, 13:09
team222badbrad's Avatar
Happy Birthday! team222badbrad team222badbrad is offline
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Great Idea, if you have limited machining capabilities/funds; however, it looks pretty heavy and it is pretty big in size.
I guess you will have to see what we have up our sleeves...
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 05-02-2006, 15:00
Starke Starke is offline
Producer at The RoboSportsNetwork
AKA: Matt Starke
FRC #0174 (Arctic Warriors); (Alumni: 340 (GRR), 1126 (SparX))
Starke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond repute
awesome transmission. very resourceful. my question is do you really need a neutral? maybe you do, but i am not sure. i would be afraid of getting stuck in neutral and then you can not do anything. am i wrong? i love the parking break incorporated though. great idea!
Team 340 | G.R.R. | Alumni/Mentor | 2003-2007, 2010
Team 1126 | SparX | Engineer | 2008-2009
FRCDesigns.com | Engineer | 2011 - Present
Team 174 | Arctic Warriors | Advisor | 2012 - Present
Unread 05-02-2006, 15:40
Bcahn836's Avatar
Iraq is fun.
AKA: Brad Cahn
We are only going to use the neutral to be able to push the robot around in between matches. The shifter will be spring loaded so as soon as the gears are lined up it will slip into high or low, so unless the spring fails we *shouldn't* have a problem with being stuck in neutral.
The parking brake is going to "set" at the end of the match as a default so if we are say half way up the ramp we won't roll back down much like putting a car into park on a hill. Then at the end of the match we will disengage the brake into neutral.
Unread 05-02-2006, 21:11
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
We did that last year, but ours was a lot smaller than that because we used gears we had originally purchased when we made our version of the tecknocats 2-speed shift on the fly in 2004. There should be pics posted from last year.
Why do teams voluntarily do FIRST without adult technical mentors? Andy Baker General Forum 127 05-12-2005 08:08
How do you organize your team? NoodleKnight Team Organization 18 03-11-2005 22:57
Top 10 seasons in FIRST History Karthik General Forum 6 01-08-2005 23:30
Improving the Efficacy of a Team Jaine Perotti Team Organization 5 24-05-2005 19:27
pic: Team 836 Teaser # 1 Bcahn836 Robot Showcase 6 15-02-2005 15:13
